Will old G35 wheels fit new G35x
Old Sep 25, 2007 | 01:40 PM
stinky's Avatar
I'm looking at some used G35 wheels (03) to use for snow tires on my '07 G35x. I was wondering if anyone can tell me conclusively whether they will fit or not. I found this thread, but obviously it's not conclusive:
https://g35driver.com/forums/showthr...heels+fit+g35x
Thanks!
Old Sep 25, 2007 | 04:58 PM
ON_6MT's Avatar
i have 17 inch aftermarket's from my 06 sedan that i used as winters and they fit.
So yes they should. Must be at least 17's thou to clear calipers.
Old Sep 26, 2007 | 11:22 AM
stinky's Avatar
Thanks for the reply, but did you see the last post in the thread above?
__________________
Audiophile
The lugnuts are different on the 07's, they have a shank lugnut that may not work with non-07 wheels. The shank lugnuts also have a small 60º seat, for use with the spare tire; though I am not sure how it will work with an aluminum wheel, or if they will even fit in the holes.
__________________
Have you (or has anyone else) tried older wheels on an '07?
Old Sep 26, 2007 | 12:33 PM
shawnost's Avatar
^ Interesting. Wouldn't a different set of lugnuts fix this?
Not to thread-jack but does anyone have a definitive answer on this? I am also thinking of getting OEM 17's from an '06 sedan for my "winter" setup.
Old Sep 26, 2007 | 12:35 PM
Klubbheads's Avatar
I have seen the coupe 19s on a 07 sedan. My guess is the 18s will fit without a problem.
Old Sep 26, 2007 | 12:45 PM
GEE35FX's Avatar
Yes you can just use the old style lug nuts with the older wheels, since the 07 uses a different style lug nut..
Old Sep 26, 2007 | 01:27 PM
stinky's Avatar
Thank you. I would like to pick up a dinged set of old wheels for cheap $$$ to put on snows.
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
kinetek
Aug 3, 2015 04:25 PM
teamghost
Jul 28, 2015 04:52 PM
laksjd84
Jul 24, 2015 05:12 PM
EasySausage
Jul 20, 2015 03:56 PM
