IMPUL Springs
#46
Originally Posted by adamr001
Don't forget you can rent a spring compressor from AutoZone and a few other places if you need one.
Originally Posted by Fast07GSdn
Can you tell me what tools were needed? Socket sizes and etc? Also, did you have a spring compressor for the front springs? I've read from the forum that you can rent one of those from Autozone for free... if you're renting it only for 24 hours.
#48
#49
Originally Posted by 07IMLG
You can use a torque wrench, but i dont know the torque specs, you also need 21mm socket for the lug nuts. I am not sure about the springs rates. But the car rides stiffer.
BTW, thanks for your help.
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
#50
#52
on
This is the best pic of the bunch to see the drop. Thanks 07IMLG for the pics and info!
Yea pretty much, you might also need 19mm or 17mm wrench for the rear bolt. The rear is easy, jus raise the back up high, so you can push the lower arm all the way down to remove the spring.
heres another pic of the drop
![](http://i34.photobucket.com/albums/d121/iml2001ser/g35/sidedrop-1.jpg)
#57
yea i got the alignment done on last thurs, everything was pretty much in spec, the front on both sides have 1 degree of neg camber, they adj. toe a little bit, on the rear they adj the camber on the rear right. After the alignment was done everything is in spec no need for alignment, i will post up the sheet soon.
#58
#59
