Help with sizing wheels.
Old Oct 31, 2007 | 03:56 PM
heyitsalex's Avatar
I've decided that I want the Axis Pentas in 20's. But I don't want to go with a staggered setup simply because I want to be able to rotate them. So my question is this, would these wheels fit my car?
20x9 5x114.3
What about the offest? What does that do and where do I need it to be?
Also, I'de like the wheels to sit flush with my fender line so that the wheels aren't inside the wheel well. Will these wheels sit flush or do I need spacers? If so, what size spacers do I need?
picture of wheels
Old Nov 15, 2007 | 12:32 AM
jimk's Avatar
i don't think 20/9's will work in the front
jim k
Old Nov 15, 2007 | 12:45 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
jim k
sure they will, it just needs the right offset. 20x9 +40 with a 245/35 would look nice all around.
-GP-
Old Nov 15, 2007 | 01:42 AM
Wei's Avatar
Wei
it also depends,
are you going to drop the car, and with what camber are you comfortable with...
I'm positive 20X9 will fit in the fronts,
I'm actually thinking of doing the exact same thing, 20X9 all around so I can rotate...
245/35/20 or 255/35/20 fits fine and they're so ridiculously cheap, it's ridiculous....
Old Nov 15, 2007 | 01:44 AM
Originally Posted by Wei
it also depends,
dropped or not a 20x9 will fit with the right offset and tire size either way.
-GP-
Old Nov 15, 2007 | 01:47 AM
Wei's Avatar
Wei
yep, I just searched, here you go:
https://g35driver.com/forums/showpos...&postcount=506
he has 20X9 +25 and 255/35 in the fronts
Old Nov 15, 2007 | 02:11 AM
terrycs's Avatar
I'm missing something ... Dazz07G35S said his tires rubbed and he was selling his wheels and tires. Wouldn't that mean the wheels did not fit?
Old Nov 15, 2007 | 02:22 AM
Wei's Avatar
Wei
I asked the exact same question:
https://g35driver.com/forums/showpos...&postcount=515
he said the rears doesn't fit, he had 20X10 +25 and running 255/35 on stock cambers, I 'think' he can fit his set up if he ran a slightly negative camber, but yeah, I'd probably get a +35 if I wanted 20X10 in the rear and dropping the car (and running maybe a -1 to -1.5 camber)...
Old Nov 15, 2007 | 02:23 AM
he said the rears rubbed when he had a load. If he increased the negative camber by 1.0 degree it would have been fine, but that would mean running around -2.5
-GP-
Old Nov 15, 2007 | 02:27 AM
Wei's Avatar
Wei
20X9 +25 in the front is pretty aggressive (to me) anyways, it really depends on your style... but at least we know it'll fit...
Old Nov 15, 2007 | 02:36 AM
i'm going to be doing an 8.5/9.5 +25 all around setup on my next set of wheels 235/255 tires, with -2.5 camber.
Old Nov 15, 2007 | 11:31 AM
terrycs's Avatar
If the guy was lowered and had the stock camber, he would have a camber kit. I wonder why he didn't dial up the camber to see if that would fix his problem. I agreee ... with enough camber, you can get a lot under there. But one has to really want that big lips on there to justify the cost of 20" tires.
But back to the OP's question ... I agree with your 20x9/40 recommendation.
-GP-
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
philthethrilloh
Sep 9, 2015 01:25 AM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
