adjusting springs after I dropped it?
Old Feb 10, 2008 | 10:46 PM
ckp's Avatar
ckp
Ok so i am sure a lot of you guys have seen my car in the thread i made after I dropped the car: https://g35driver.com/forums/v36-brakes-suspension-wheels-tires/196886-dropped-car-pics-inside.html
I love EVERYTHING about the drop, but i feel like the front is just a little bit too low, I would be happy if i could bring it up maybe 1/4", because the front tire is tucked under the fender just a hair (see the picture below).
Now my question is can I have my springs adjusted so that it raises the front up just a little bit? or once the car has been dropped you can't make any adjustments with the springs? Thanks in advance!
Sorry i had to put the pic as an attachment, I don't know how to make it big (im retarded when it comes to computers, lol)
Old Feb 10, 2008 | 10:57 PM
EWG35's Avatar
If you just installed lowering springs i.e Eibach pro kit, you cannot do anything to the springs to make them higher. I saw a show yesterday about eibach. The springs are a matched set and the spring will appearantly always return to the original ride height no matter how long there are on your car. I'm not aware of any shims, but that may be worth looking into.
Old Feb 11, 2008 | 07:41 AM
hokiesean24's Avatar
Wow- thats pretty low. If the roads are like they are here, you have to scrape everywhere. There are some spring spacers/cushions out there. I had looked into them when I first dropped my car. I wanted to bring my front back up about 1/8 - 1/4" too. I ended up not doing it. They are pretty cheap. Run a Yahoo/Google search and start looking. There are some generics and then there are some more size specific ones that your order based on the diameter of the spring and the width of the spacer you want... I wish I could remember a brand name or something, sorry. Goodluck!
Old Feb 11, 2008 | 10:37 AM
TheIvoryG's Avatar
I looked into spring spacers when I first dropped my car...the shop I went to highly recommended [I]not[I] using them. Said they just weren't a good idea for right or dependability. He never quite gave me a good answer, then I got used to the drop so haven't looked further into it.
Has any body ever used spring spacers?
Old Feb 11, 2008 | 11:07 AM
gary c's Avatar
Having worked on brakes/suspensions for most of my adult life I discovered
years ago when guys wanted a cheap way to raise there cars they used
spacers only to discover it ruined the way the car rode. Your throwing
chunks of metal between the spring links, that's just bad!
Old Feb 11, 2008 | 11:12 AM
Most of the ones I saw were made out of a really hard rubber, so it had some give in it. Not saying they didnt use metal ones at some point, but I am pretty sure there are rubber ones available now. I would imagine that would be better than metal as far as ride quality, I am sure it would still hurt it to some degree though-
I would be curious if anyone has actually done it-
Old Feb 11, 2008 | 12:32 PM
Wei's Avatar
Wei
I actually like that drop, looks really nice
but yeah, get another set of springs if you're unhappy with that height, or wait for a height adjustable coilover...
I personally don't like the idea of spacers for anything...
Old Feb 11, 2008 | 12:36 PM
ckp's Avatar
ckp
thanks I dont really wanna spend that much $$ again for springs plus install.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Kelvin Style006
May 23, 2016 03:47 AM
HeyAsianKid
Intake & Exhaust
Oct 7, 2015 01:55 PM
DRG35R
Sep 16, 2015 05:33 AM
