Tire Pressure Sensor
Old Apr 25, 2008 | 10:31 AM
coupin827's Avatar
Glad I'm not the only one having problems.
Old Apr 25, 2008 | 12:05 PM
Ghozt's Avatar
I had my replaced twice, different tire each time. The reason they told me was the winter up here causes the sensor to go bad, I think it is BS.
No, I swap on my summer tire/rim, the light is on again. I thing the ****ed up the program when they replaced my senor on my winter rim.
Old Apr 25, 2008 | 07:25 PM
mlimg35x's Avatar
After getting my first oil change from the dealer, I'm having the same problem. Can I go to any Infiniti service (covered with warranty) or do I need to go to the one I purchased at? How long does it take to reset the sensors.
Old Apr 25, 2008 | 07:47 PM
SVLRx's Avatar
i had a flat yesterday, and the light went on, figured it was the rear tire, checked the pressure and it was at 15psi.... Got the tire repaired and after driving about 3 blocks the lights went off.... Guess mine works fine, it's not as nice as the set up in my dad's Chevy avalanche (tells you pressure in each tire) but it does serve its purpose, b/c w/o it I didn't notice the tire was flat
Old Apr 27, 2008 | 09:40 AM
hrp783's Avatar
im having problems too...
i will drive around and the light wont come on, then all of a sudden the light will start flashing, or stay on... then randomly it will turn off....
anyone else having the same problem?
dealership checked the tire pressure and said its all good, my rear tires are bald... wonder if that is the problem...
what you guys think?
Old Apr 28, 2008 | 05:26 AM
urstruly83's Avatar
How do u check the tire pressure anyways in the car, I cant figure that out for the life of me!!!!!!!
Old Apr 28, 2008 | 05:51 PM
MiniRX7's Avatar
I know how to reset the light, there is a special procedure that the nissan guys dont know.
But i think its time to cut the light. Even the murano has the true tire pressures. Whats a light going to tell me othe rthan constantly malfunctioning LOL
Old Apr 28, 2008 | 06:04 PM
hrp783's Avatar
how do u reset the light??
Old Apr 28, 2008 | 09:53 PM
G35Now!'s Avatar
Moderation-free
Check the manual, but in general you air the tire back up to the right PSI, then drive over 25 mph (I think) and it should go off. Some of us have had trouble with ours, and had to have them re-registered or replaced.
jsimonk
Dec 22, 2023 03:49 PM
Muski_G
Dec 1, 2023 11:11 AM
joedaddy1
Jul 28, 2015 02:58 PM
stay_tuned
Jul 21, 2015 07:09 PM
