can i fit 21x10 inch rims on my stock height g35 sedan 2008
i can get a really good deal on some 21 inch dornells 2 piece 5 star design but do not think they will fit. any help would be great thanks. sorry i forgot to mention it is a lease so i cant mess with rolling the fenders etc. thanks.
Originally Posted by GLuXuRy
dont make the wheels fit the car ... make the car fit the wheels
stretched tires ... negative camber and fender rolling should help
but ya they should work fine
but u need a drop so your camber will be negative or it'll rub
Yes. As long as you have the correct offset and tire size, 21x10" rims will fit in the rear with no problems. 21x10 up front would be pushing it. I wouldn't go wider than 9" up front.
On a 10" rim, you can run offsets from +50 for conservative to about +40 or even lower if you run enough camber and stretch your tires.
Here's a link to "The Punisher's" lowered G35 with 22" rims - check out page 3 for more pictures:
https://g35driver.com/forums/picture...0-car-22s.html
I'm getting a set of wheels with 9.5 +35 and 10.5 +37 soon.
It would require some negative camber with some height adjustment from my coils... but I'll make it work for sure... hahaha BTW, I won't go any more negative than -2.0 on camber.
wow thanks for all the help this forum is very good for questions. the set im looking at are 21x9 front with 245/35/21 and the rears are 21x10 295/35/21 i think the back tire will be to large with keeping everything stock right also heres a pic tell me what you think thanks. also i believe the offerst are +35 only will that work im pretty new to the offsets and camber and all that thanks sorry for so many questions.
http://thumbp1.mail.sp1.yahoo.com/tn...=453&fid=Inbox
I wouldn't attempt 21x10 +35 295-35-21 at all. That will most likely rub and will definitely stick out the wheel well.
What I suggest is to just run 21x9 +35 at all 4 corners. That should be fine.
TWASkyliner
Feb 8, 2020 08:00 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
newbdriver01
Jul 15, 2015 06:10 PM
