New brakes after 3 months?....
Old Oct 16, 2008 | 07:09 PM
calibur45's Avatar
Originally Posted by airhoppz
I've had some squealing on my sedan as well, usually when backing out of parking spaces. What gives?? I have just over 30K on my car, but a lot of that mileage was highway miles and not a ton of braking.
i had this too.. it is brake dust buildup.. go to the dealer and have them clean it and it will stop
Old Oct 18, 2008 | 11:03 PM
puga's Avatar
I have the same problem. Are the rotors covered under warranty? I have an 07 sedan with 23K miles.
Originally Posted by kool_yaar
22k+ here and my pads are still alive but my wapred rotors need replacing, all the vibrating is starting to dirve me crazy, wheres the money...
Old Oct 19, 2008 | 08:15 AM
Texasscout's Avatar
Not likely.
Old Oct 19, 2008 | 08:16 AM
Texasscout's Avatar
Never heard of brake dust doing this????
Old Oct 19, 2008 | 08:39 AM
snotf's Avatar
Originally Posted by tg1234
I had to change tires around 12k and I had to replace my brakes around 20k. All 4brakes were equally worn. How do you drive? It all depends how you drive.
I agree with others. Check it yourself or get somebody to ceck it for you to make sure they not screwing with you.
tg
i don't understand how all four had even wear, it was my understanding of the braking system that generally the front brakes did most of the work... is this not true?
Old Oct 19, 2008 | 09:32 AM
Texasscout's Avatar
That's true, however the "swept area" of the disc and "surface area" of each pad in the rear is engineered to compensate in that respect so wear rates are close to the same. Now I had a 97 Ford F-150 and when it had died with 300K+ on it, it had gone through 5 sets of front pads, yet had the same brake shoes in the back.
Old Oct 24, 2008 | 07:45 AM
airhoppz's Avatar
I just had my car serviced and they checked everything and said it was good. So what now?
Old Oct 24, 2008 | 11:31 AM
suby01's Avatar
on my 07 with 18k the car shakes when i break hard. the pads seem fine so it has to be the rotors. is that covered un wrnty. or is it time for stillen cross drilled?
Old Oct 24, 2008 | 11:57 AM
pinkii's Avatar
Mine started squeaking at 17K, got the fronts replaced at around 25K. I will need to get new everything since I cant find any brake pads to fit on the stock crap except the same crappy pads I had on the first time.
Old Oct 24, 2008 | 02:50 PM
Texasscout's Avatar
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old Oct 24, 2008 | 02:54 PM
huf's Avatar
huf
You need to get second and third opinions.
11bEMT
May 27, 2022 03:13 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Lsantana757
Jul 20, 2015 09:08 AM
