Do these really make that big of a difference? Who has these? Thanks!
http://www.stillen.com/product.asp?i...NITI&model=G35 4DR
i was wondering the same, i will double check this post to see what the other guys on this forum say...
they will improve braking force and less braking travel and will work a lot better with BBK lol
im answering all your threads bro hahaha
The whole idea is that the SS braid helps to minimize the brake line expansion under pressure.
So, if the line expands less, the pressure of the master cylinder is applied more efficiently to the brake caliper.
This is even more important as things heat up.
That said....
- For street daily driving you will notice very little.
- If you are aggressive, spend time on the twisties etc; you will definitely notice the difference.
- if you track, ....no brainer.
BTW....
I had them on my 1st gen G35 & my Z4 M. (which I have tracked)
- I don't see myself installing SS lines on this car until lines need to be replaced.
ALSO
If you get SS lines, don't go cheap!!!
Get coated lines with boot shrouds at the connectors.
Unprotected lines are prone to breaking down due to dirt getting into the braid (friction)
When SS lines break down, they usually rupture whereas rubber lines just leak.
That said....
BTW....
ALSO
off the topic, but my car makes a rock/ squeaking noise when i start to brake.. any idea why and how can i solve this ? i took it to firestone for a quick check up. they said i need to resurface my my rotors and change the hardware..
it's all good, it's a reminder I need more mods, headers and ECU!!! LOL I want more HP. Cobb is lagging... pissing me off, and tadashi never returns emails!Originally Posted by G35Robby
they will improve braking force and less braking travel and will work a lot better with BBK lolim answering all your threads bro hahaha
I'd recommend them for almost any car if you are a hard driver like me. I put them on my '04 when I did an OEM Brembo upgrade. Then again I also did a few things to the brakes all at once. I currently looking for a set for my DD RAV4, can't seem to find any. I'll report back when I do.
spray some undercoat on your lines and you should be good to go for the life of the car.
i only see changing them if you track the car often or drive the streets regularly like a retard
use the $$ for something else
