Why am I getting a low tire pressure warning light.?
Old Dec 16, 2008 | 11:46 PM
04G35NYC's Avatar
same thing as me also, the cold, these sensors are really sensitive but i don't' pay attention to them. I check my tire pressure every week or so just in case.
Old Dec 17, 2008 | 09:55 AM
Virus's Avatar
I've had to have a couple of the sensors replaced. Mine would come on and not go off. I check my pressure every weekend and it's never been low.
Old Dec 19, 2008 | 09:00 PM
FloridaNative's Avatar
Might be a sensor problem. My tire pressure light was on driving my car off the dealer lot. They said it would go away, but it didn't. Tire Pressure in all tires were fine. I had to deflate my tire and reinflate it for the light to go off. What do you know, it happened again. Getting it checked next week. Don't let them Bullcrap you.
Old Dec 20, 2008 | 09:30 AM
STCLAIRWEST's Avatar
oxygen has to much moisture that makes it has less air in the tire. i heard nitrogen well stop that problem
Old Dec 20, 2008 | 10:46 AM
G35Now!'s Avatar
Moderation-free
To clarify your post, air (like other gases) will hold moisture in the form of humidity. This can make it more susceptible to pressure changes due to temperature. Nitrogen can fix it simply because it is typically dehumidified out of the tank. However, I've had both and can tell you there's no appreciable difference.
Old Dec 21, 2008 | 02:39 AM
ez-g's Avatar
Boyle's Law. Temperature is inversely proportional to pressure in a closed system (such as a tire) so when it is cold, add air. Rule of thumb is about 1 psi per 10 degree drop in a tire.
Old Dec 21, 2008 | 02:25 PM
loudog's Avatar
There is another thing to watch on the TPMS
I just had my G in for it's 15k check and it had an issue with the TPMS. If the TP light is flashing at startup, you have a sensor/system issue. If it's on constant, check your pressure.
-- Lou
Old Dec 21, 2008 | 03:50 PM
dofu's Avatar
20 Year Member
-- Lou
Any light flashing at startup is perfectly fine. But if you have an issue with the TPMS it will either turn on, or it will turn on for 2 seconds, off for 0.2 seconds, and keep repeating. If it's a single TPMS sensor, it will blink in sequences.
tal1412
Nov 28, 2022 09:25 AM
joedaddy1
Jul 28, 2015 02:58 PM
