Question about tires
Old Jan 29, 2009 | 05:30 PM
timpiroli's Avatar
I have been thinking about buying the sport rims for my G35x. I know that a staggered setup is not recommended but here is my question. I am going to buy all front rims 18X7.5" I know that the factory tires that come on the Xs are the Dunlop Sport Maxx A1 A/S 225/50R18. I am not very keen on Dunlop tires so on to the real question. I like these tires:
Bridgestone Potenza RE960 Pole Position A/S size 225/45R18
http://www.tirerack.com/tires/tires....1=yes&place=30
Will these tires have any effect on any of the systems on a 2008 G35X? IE speedo etc???
All input would be appreciated!!!
THANKS
Old Jan 29, 2009 | 06:25 PM
GEE35FX's Avatar
Your new tires would be .7" smaller diameter and your speedo will be out by 2.9%. If you can live with that you will be okay, I know I would rather run something a bit closer to the stock diameter.
Old Jan 29, 2009 | 06:29 PM
AesonVirus's Avatar
Tire calculator
Old Jan 29, 2009 | 07:06 PM
nghiars's Avatar
Are they not available in 225/50/18?
Old Jan 29, 2009 | 07:27 PM
kregg's Avatar
I would suggest 245/45 18's. This is the size I am going for on my 18" OEMs that currently shod the Dunlops. This works out to 0.7% different or less than 1 mile per hour off at 60, which is well within typical variance for spedo's. Plus wider tire = better handling.
Old Jan 29, 2009 | 08:10 PM
GEE35FX's Avatar
I'm also running 245/45/18 PS A/S tires, but on 8.5" rims. They work well.
Old Jan 29, 2009 | 08:18 PM
timpiroli's Avatar
Thanks for all the help guys, I do have another question. If I do decide on going with the 18X8.5 will I need spacers?
So you like these tires? Are there any good or bad points to these tires?
THANKS
Old Jan 29, 2009 | 10:19 PM
AesonVirus's Avatar
THANKS
I'm running 19x8.5 and I didn't need spacers.
Old Jan 29, 2009 | 11:01 PM
GEE35FX's Avatar
THANKS
I love these tires and I am very happy with the performance and handling. The size is perfect for me.
I had the 225/55/17 on for one week, then I ran 255/40/18 PS2s for a while since they were used and on the rims I bought. Then I settled with the 245/45/18 PS A/S tires.
The only downside that I had was they are a pricey tire.
Old Jan 29, 2009 | 11:06 PM
GEE35FX's Avatar
THANKS
Are you talking about using the 8.5/18 OEM rear sedan sport rims all around.
If so the fronts will be tucked in quite a bit. It would definitely look better with spacers front and back since they are 50mm offset.
Old Jan 29, 2009 | 11:24 PM
timpiroli's Avatar
Yeah I am looking at the OEM 18" Sport rims.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
