spacer suggestions
Old Feb 18, 2009 | 02:28 PM
Texguy's Avatar
Thanks, Adrian. Can't see pics from work. Will do when I'm at home.
Old Feb 18, 2009 | 03:23 PM
2GoRNot2G's Avatar
No problem, man.
Definitely let us know what you end up with and how it goes.
Old Feb 19, 2009 | 03:34 AM
booost7's Avatar
in m opinion H&R spacers z the best choise i already bought 20mm it gives awsom look for my G
Old Feb 19, 2009 | 08:17 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by AesonVirus
Careful on the ebay ones... I've heard stories about some being low quality. Some of the cheaper ones may not be 100% true and can cause the wheels to wobble a bit.
Stick with name brands on ebay whenever possible.
^ I'm of the same opinion.
We're dealing with safety here.
You really need to check the specs.
Most of the e-bay ones say they are aluminum but do NOT say what grade of aluminum.
Unfortunately, those Alum/Mag alloy ones that 2GoRNot2G found aren't listed any more.
Old Feb 20, 2009 | 05:08 AM
2GoRNot2G's Avatar
I am very familiar with the supplier that makes the one's I used, as they have made other items for me for my business. They definitely make very high quality product. I'm surprised they are not listed anymore, as my buddy just bought a set for his Z from the same supplier on eBay just the other day. I will check with them and see if they are still available.
Old Feb 20, 2009 | 09:59 AM
Texguy's Avatar
I bought from ebay the other day. The spec said alum/mag alloy, but the studs are not the same color as Adrian, so I don't know. Will see when it gets here. BTW, I don't need a realignment for spacers right?
Old Feb 20, 2009 | 02:12 PM
2GoRNot2G's Avatar
Nope, no alignment needed, Tex.
You have a link to the one's you bought? Just curious.
I wouldn't worry about it too much, though... As long as the spacer is hubcentric, made well, and the studs are strong, then there's not much that can go wrong with spacers. Since they are clamped between your wheel and factory hub, most of the lateral forces are transfered to the factory studs and hub anyway... Your main concern is if the are true, so you don't get wheel vibrations.
Old Feb 20, 2009 | 07:17 PM
Texguy's Avatar
here is the ebay link, http://cgi.ebay.com/ebaymotors/20MM-...Q5fAccessories
Old Feb 20, 2009 | 07:20 PM
AesonVirus's Avatar
Do you guys suggest the same size all the way around?
Would it really hurt anything to go with something like 15's in the back and 10's in the front?
Old Feb 20, 2009 | 08:23 PM
2GoRNot2G's Avatar
Originally Posted by Texguy
These are exactly the same ones I got. Same vendor and everything. These guys make these right around the corner from me in Santa fe Springs, CA. Looks likt they raised the price on them, though... $88 is still very good for this material and this nice of quality.
Nope, you shouldn't have any problems as all, although, if you are running these with the factory wheels, then you will want the thicker ones in front, since the factory rears are already slightly more aggresive in the back. If I had to do it over again, I may only go with 15 mm in the back and keep the 20 mm up front... the 20's up front a prefectly flush right now, but the rear sit out a little less than a 1/4"... of course, when I lower the car, then the rears should tuck in very nicely. One other thing to think about is if you go with 10mm spacers or less, then you will most likely have to get the type of spacers where you have to actually remove the factory studs and press in longer studs that run through the spacers. This is actually probably a better way to do it, but makes it a much harder install.
Old Feb 20, 2009 | 08:48 PM
AesonVirus's Avatar
I'm in an X so all four corners have the same offset.
I just think it'd look a little better if the rears were ever so slightly out more than the fronts.
Old Feb 20, 2009 | 09:01 PM
2GoRNot2G's Avatar
Yeah, since your factory fronts are the same width and same offset as the factory sport wheels, then a 20 mm should work well for you. For your rears, since they are only 7.5" too (~25 mm narrower than the sport wheels) with a 45mm offset (5mm less offset than the sport wheels). then you would need a wider spacer in the rear to push them out to the same point as where my sport wheels are. 25 mm /2 = 12.5 mm - 5 mm = 7.5 mm = the extra spacer thickness that you would require to push your 7.5" wheels out to the same point as my sport wheel, so I would probably go with a 25 mm spacer in the back. Make sense? LOL
alessandro
Oct 8, 2015 09:29 AM
bigmike
Sep 17, 2015 01:58 PM
Terry_G35
Sep 10, 2015 08:17 PM
Machine Head
Sep 4, 2015 07:22 PM
