Will spare tire fit over *rear* Akebono brakes?
Old Mar 21, 2009 | 10:35 PM
soundmike's Avatar
Anyone?
Thank you.
Old Mar 23, 2009 | 09:38 AM
tonke73's Avatar
If this is the same spare tire that came with the vehicle, then yes it will fit.
I wish the Gs had the Brembos instead of the Akebonos. Akebonos don't bite like the Brembos did.
Old Mar 23, 2009 | 09:40 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Bite is usually in the pads, not the calipers.
Old Mar 23, 2009 | 10:02 AM
tonke73's Avatar
You are correct. I had Hawk HPS pads on my 03 G35 Brembos and they didn't bike like stock. I was expecting my 09 g37 Akebono brake system to bite like the brembos. I guess that Infiniti listened to all those people bitc*ing about how sensitive the brakes were and maybe reformulated the pads. I never had a problem with the sensitivity of the brembos.
Sorry to jack your thread.
Old Mar 23, 2009 | 11:24 AM
soundmike's Avatar
Thank you. Tonke, yes, i'm referring to the stock spare that came with the sedans. If it fits the rears at least then this is a worthwhile upgrade. Otherwise, i'm going to have to find a larger spare.
Old Oct 1, 2009 | 01:48 PM
InTgr8r's Avatar
TTT
...aside from the G37 spare has anyone found any other spare that works?
Front & rear, I doubt that my 10" rear will swap to the front.
I'm waffling back & forth which way to go here.
My Z4M had no spare & just had a roadside comp/kit.
...I was lucky to never have needed to use it.
For those that have changed to the Akebono, just wondering what you did?
Old Oct 12, 2009 | 08:28 PM
E-Ticket Ride's Avatar
Originally Posted by soundmike
Anyone?
Thank you.
IIRC, you need the 37 spare. The 35 spare won't work.
Old Oct 13, 2009 | 12:23 AM
terrycs's Avatar
Correct. I had to get a G37S coupe spare (which came with the akebonos) to clear my front StopTechs because my stock G35 spare wouldn't work.
Old Oct 13, 2009 | 03:17 AM
Does that spare fit in the same compartment in the trunk that our spare sits inside of?
Old Oct 13, 2009 | 03:36 AM
B L U E S L A T E's Avatar
Honda Accord
^Yes it should. I'm currently looking for the 37 spare as well... it's kinda hard to find one. :/
Old Oct 13, 2009 | 07:21 AM
soundmike's Avatar
ooh, an oldie!
Thanks guys, i eventually figured this out after i got the kit.
Check out car-parts, i found a couple of G37 spares on there before, but they weren't local and the shops that had them charged an arm and half a leg for shipping.
Old Oct 13, 2009 | 07:57 AM
InTgr8r's Avatar
^Same problem here....
I'll probably end up going with the Conti kit until I find one.
$80 at Tirerack
Old Oct 14, 2009 | 08:31 AM
soundmike's Avatar
Since the spare fits over the rears, assuming you have a rear flat, it's not an issue. For a front flat, as cumbersome as it sounds, one could do a three-point swap-out between the front, rear and the spare.
Old Oct 14, 2009 | 09:20 AM
InTgr8r's Avatar
^ I was thinking that, except I'm not sure that my 10" rear will work up front.
Old Oct 14, 2009 | 10:13 AM
Honda Accord
In my case, 10.5.
That conti kit looks pretty good. I might have to get one just in case.
