Burnt rubber smell coming from front tires...
Old Apr 17, 2009 | 03:53 PM
Eug96's Avatar
Hey, hopefully I can get some input on this situation...
I dropped my car on eibachs about a month ago, had the rear spc camber installed 2 weeks later. I cant seem to tell outside but once I pull into my garage where there is no wind, I can smell sort of like a burnt rubber smell when close enough to the front tires. Is this the front tires taking a beating from the neg camber? Or something more serious I should have checked out?
Old Apr 17, 2009 | 03:56 PM
JP1080INC's Avatar
check to make sure your inner tires are not rubbing up against anything.
Old Apr 17, 2009 | 04:00 PM
Eug96's Avatar
ill go check right now lol 1 sec
Old Apr 17, 2009 | 04:06 PM
Eug96's Avatar
from what I can see it doesnt look like the inner part of the tire is rubbing against anything
Old Apr 17, 2009 | 04:11 PM
JP1080INC's Avatar
i would just take the wheels off and inspect them.
Old Apr 17, 2009 | 05:02 PM
jran76's Avatar
Do you know the wheel sizes/offsets, and the tire sizes?
Old Apr 17, 2009 | 06:03 PM
Eug96's Avatar
wheel size is 240/40/19 ill get back to you with the offsets
Old Apr 18, 2009 | 10:42 AM
johnnyzee's Avatar
as for camber:
camber will not cause a burning smell as camber only relates to the tires being driven with more load on the inner treads vs. using the whole tire more (in your case at least)
____
hey eug, stupid question but did you do an alignment (it could be possible toe sheer)?
Are you sure you're not smelling your brakes (rather than your tires)?
Are you driving the car hard making the tires work?
Your tire size doesn't justify any rubbing but it all depends on your offsets... do your tires sit closer to flush with the fender or do they sit very tucked in the fender? If I remember right, those pics of your rims/car i saw a while back, i don't think this is your issue.
Old Apr 18, 2009 | 05:15 PM
Eug96's Avatar
yeahh I had an alignment done, and im not driving the car hard at all. Possibly could be the breaks. I think my best bet might be to go to infiniti and have them take a look just incase it is the breaks.
Old Apr 18, 2009 | 05:33 PM
lilindienplaya's Avatar
maybe its your brakes, or possibally its the tire slipping on the rim, after a drive and you smell the smell get out and feel the lip of the rim and see if it hot.
North NJ G
Steering & Suspension
12
May 27, 2023 01:14 AM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
bjo16
Aug 4, 2015 09:52 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
newg37
Jul 26, 2015 09:32 AM
