Need a alignment?
Old Oct 3, 2009 | 10:59 AM
Hydroxs's Avatar
Need a alignment?
Is it normal that that the rear tires wear out faster then the fronts? Both my rears has about 2/32'' remaining while the fronts has about 5/36" remaining. Also on all four tires, the outer edge is more worn then the inner edge (as much as a 2/32" difference on some of them).
Old Oct 3, 2009 | 12:34 PM
nghiars's Avatar
this is a RWD car so the rears will wear out faster. it is unusual that your outer edges are wearing faster than the inner edges. should be the oher way around if anything.
Old Oct 4, 2009 | 09:13 AM
johnnyzee's Avatar
^true
it is unusual for the outer edges to wear first. I'd do an alignment if i saw that happen.
Old Oct 7, 2009 | 08:09 PM
gassian's Avatar
Actually I have the same tire wear as you are seeing.
All my outer tires are more worn than inner ones. It also depends on how fast you taking turns and stuff.
Also yes rear will wear out faster than fronts.
I am in process of getting new tires.
Old Oct 8, 2009 | 11:41 AM
Austin713's Avatar
i have the same issue. i got an alignment and they said they adjusted the toe a bit. i dont take corners very hard but i do drive a bit spirited at times.
Old Oct 8, 2009 | 12:26 PM
djwishuwur's Avatar
Whether your tires are wearing on the outside first or the inside (like mine do) I'm certain that all G owners would benefit from regular alignments. Even if you're crusing on the stock suspension. I don't know if the car just jumps out of spec fast or if the tolerances are just really small. Either way, I've got lifetime alignments and I'm getting a new one every few months. Otherwise, I'd never have a tire live up to it's waranty. Yeah, I'm sure getting them every few months is a bit extreme but once you buy the lifetime deal, you might as well.
Old Oct 8, 2009 | 12:44 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^ do they not regulate how often or how many /yr?
Old Oct 8, 2009 | 03:11 PM
terrycs's Avatar
I purchased a lifetime alignment at my local Fierstone dealer. No limits.
Old Oct 8, 2009 | 03:39 PM
djwishuwur's Avatar
I've got the same deal as Terrycs. I think I paid about $160 or $180. Just has to be the same car.
Old Oct 8, 2009 | 06:57 PM
RBull's Avatar
Rated M
^that has to be a huge loss leader. It doesn't seem to make any sense to me but they must have reasoning for it.
Old Oct 8, 2009 | 08:11 PM
Hydroxs's Avatar
The car almost 2 years old and I never had an alignment lol. I guess it is time to replace the stock tires. Should I just replace the rear and get an alignment for all four tires or replace all 4?
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
MThawkins86
Oct 24, 2015 02:07 AM
Benja455
NorthWest
Sep 23, 2015 01:10 PM
migurus
Sep 5, 2015 09:39 PM
