Are +20 offset 8.5 or 9.5 wide wheels too aggressive on a sedan?
Old Jan 14, 2017 | 02:31 AM
  #31
HBassassin's Avatar
Originally Posted by IvoryPearl07G
i was running 20x8.5 20mm offsets on the fronts and 20x10 40mm offset on the rears and they sat perfectly flush with the car lowered on H&R springs with neg camber and stretched tires
im now running 17x8.5 24mm offset fronts and 17x9.5 38mm offset rear with only a few mm difference. but the tires make it appear perfectly flush
so the tires and rims i picked out shouldnt stick out? right? im not sure what the offset is on the xxr 521s
Old Jan 14, 2017 | 02:33 AM
  #32
HBassassin's Avatar
Originally Posted by B L U E S L A T E
You'll be fine with +20 on 8.5 and 9.5.
but what about 10" in back? would it rub with tires that arent stretched?
Old Feb 11, 2017 | 11:36 PM
  #33
larrydavid's Avatar
wide aftermarket coupe wheels on sedan?
I have some aftermarket wheels (18x 8.75 & 9.75 both +20 offset) from my old '06 coupe, is there a prayer of fitting these on an '04 g35x sedan?
edit: should mention the g35x sedan is 100% stock.
Old Dec 3, 2023 | 11:49 AM
  #34
mike_meza12's Avatar
Infiniti g35 coupe with bose audio system
I’m looking into buying new rims for my g35 coupe but i don’t if there about to be poked or perfectly flushed. The rims i’m looking at rn are 18x9 with 20mm offset all around. Lug pattern is 5x114.3. can someone plz tell me if i should buy them or look for more. I am looking for a perfect flush fit.
these are the rims that i am currently looking at . Can someone also tell me if they will look good on a g35 coupe.
This is more information about the rims.
friedsqrl
18 Inch
11
Aug 9, 2015 12:41 PM
reaper76
Aug 5, 2015 10:13 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
Soumilg
Jul 18, 2015 12:33 PM
