wheel replacement?
Old Nov 14, 2009 | 03:41 PM
fireman's Avatar
wheel replacement?
Hi everyone, I'm new to this forum...I recently purchased MY07 G35 sedan, got the interior trim scratches fixed by the local dealer, the lady I brought the car from had curb marks in all four wheels stock sits on 17" so I brought a set of 19" G35 Coupe stagger wheels/tires from EBAY...here is the question, the new wheels are 19x8 Front with 30mm offset and 19x8.5 Rear with 33mm offset will these wheel fit on my 07 G35 sedan? mod/spacer or lower needed? thanks
Old Nov 14, 2009 | 03:50 PM
smr514's Avatar
welcome to the forum, they will fit no problem.
Old Nov 14, 2009 | 04:01 PM
fireman's Avatar
also, does anyone know the stock offset for the MY07 G35 sedan 17" and 18" stagger wheels?
Old Nov 14, 2009 | 07:51 PM
soundmike's Avatar
17x7.5 +45
18x7.5 +45
18x8.5 +50
Spare is 17x4 +30
Old Nov 28, 2009 | 02:32 PM
fireman's Avatar
finally got the wheels from Fedex...I'm thinking about lowering springs but don't want to have bumppy ride and dealing with camber/toe readjustment...anybody have any suggestion of which brand/type of lowering springs that dose not require camber/toe kit?
Old Nov 28, 2009 | 05:35 PM
soundmike's Avatar
I think only the Tanabe's are the only aftermarket springs you can install that will allow you to be either within, or at least get close to, the OEM camber/toe/caster specs. Coilovers would be your next best bet.
rezendvous420
May 31, 2020 01:26 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
atk08
Jul 30, 2015 03:12 PM
itschuckster
Jul 25, 2015 08:07 AM
nascarbuff17
Jul 16, 2015 10:23 AM
