Akebono vs Stock brake weight
Old Dec 8, 2009 | 07:26 PM
Mainer's Avatar
Hey these are just approx used a bath scale, Akebono/Stock 07 G35S Sedan
Front Caliper 9lbs/14lbs ea. Rear Caliper 5lbs/6lbs ea
Front Rotor 24lbs/24lbs ea Rear Rotor 18lbs/14lbs ea
Total if my math is right Akebono BBK114 /Stock 116
Old Dec 8, 2009 | 07:31 PM
ttrank's Avatar
Grocery getter
Really? I was under the assumption from another owner that they were a lot heavier than the stock ones (~6-10lbs per corner).
Old Dec 8, 2009 | 07:36 PM
Mainer's Avatar
Unless my scale is just being nice in letting me think my new bbk is less weight it is true. I weighed them twice. I wasnt surprised the Akebono calipers were less because I believe they are aluminum or aluminum composite, I think the stock ones are cast iron. The rotors is what really threw me I thought the brake pros would be way heavier not so.
Old Dec 8, 2009 | 07:51 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Pretty sure your scale is off.
The rotors are definitely heavier (larger), you should be able to feel the difference by hand.
...that's why we're so keen on finding a 2pc rotor for the front at least.
Old Dec 8, 2009 | 07:54 PM
ttrank's Avatar
Grocery getter
I need to ask OCG35, he weighed his before they went on.
Old Dec 8, 2009 | 08:04 PM
ttrank's Avatar
Grocery getter
He said that he believes the fronts are 30lbs and the rears are 19lbs. The caliper weights don't shock me but I am shocked if the stock fronts are as much as the big ones.
Old Dec 8, 2009 | 08:16 PM
Mainer's Avatar
Sorry if my figures are off, I couldnt believe it myself thought I must need new glasses!
Old Dec 8, 2009 | 08:26 PM
ttrank's Avatar
Grocery getter
You may not be, I have never weighed them in person. I have a set of 05' coupe brakes at my house and they are quite heavy.
Heck, my current brakes are very, very heavy.
Old Dec 8, 2009 | 10:45 PM
E-Ticket Ride's Avatar
I was under the impression that the majority of the weight difference between the g35s and g37s was the larger brakes
Old Dec 9, 2009 | 06:12 AM
Mainer's Avatar
I heard and read that the major weight difference is between the engines, now the brakes it may be, but dont forget I purchased the brake pros rotors and not the ones that come on the G37S.
Old Dec 9, 2009 | 08:48 AM
Mainer's Avatar
Hey also my original rotors are the 13" f & r on the G35S that probably makes a difference over the stock G35 which I think are 12.4 Front.
Old Dec 9, 2009 | 05:23 PM
ttrank's Avatar
Grocery getter
Oh yeah, I didn't even think of that! Never mind, my numbers were all based on the 1st gen V35 platforms.
Old Dec 11, 2009 | 02:25 PM
InTgr8r's Avatar
Yes but the Akebono are 14" which is a significant additional mass.
FWIW, found on a rotor mfg web site;
OEM Akebono fr. rotor = 30.0 lbs.
Old Dec 11, 2009 | 03:44 PM
Mainer's Avatar
But like I said I am not using akebono rotors I am using brake pro (stillen) rotors that are slotted
Old Dec 12, 2009 | 01:38 AM
terrycs's Avatar
Are they 2 piece rotors? Having aluminum hats make for additional weight savings.
