using sport suspension on X
Old Dec 31, 2009 | 01:40 PM
bat6wc's Avatar
I know this had been brought up before and I tried searching with no luck. Would there be any advantage(both handling and looks) to using the Sedan S springs on my X? Anyone done it? I am tempted to switch to the sport springs and sport rear sway in hopes to improve the handling and looks ever so slightly.
Old Dec 31, 2009 | 01:49 PM
AesonVirus's Avatar
Dont waste your time.... Eibachs!
Old Dec 31, 2009 | 01:54 PM
Holmes35's Avatar
^^^ Def go with Eibachs....your G will look sick and the cornering will be much flatter as well as your car being more aerodynamic and of coarse super sexy!
i doubt you would even notice much difference just changing the springs from the x to sport springs....also i believe the Sport has better shocks so if you change to sport springs without the sport shocks...well you see what i am getting at
Old Dec 31, 2009 | 02:00 PM
bat6wc's Avatar
haha. i just cant chance it with the eibachs. I cant drop that low in my area. Ive done it before and I cant do it again. i need the ground clearance. Its basically IMPUL or nothing.
Old Dec 31, 2009 | 03:02 PM
E-Ticket Ride's Avatar
You need to find out the difference in spring rates to see if it's even worth it.
Old Jan 5, 2010 | 06:59 AM
BlueFlash's Avatar
i'll tell you how my IMPUL experience turns out this week. I have an appointment for an install+alignment this Thursday.
I've had 2 cars in the past that i've slapped springs on and had the immediate bounce effect, so i will be very biased with the IMPUL test drive.
I drive about 400 miles a week.
Stay tuned....
Old Jan 5, 2010 | 09:18 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
That's a consideration for all springs used on the X.
IIRC none of them are actually designed for the X.
Old Jan 5, 2010 | 09:23 AM
InTgr8r's Avatar
Stay tuned....
Has Impul pricing changed at all????
Just wondering with all the other competitive options out there (including COs),
if they have lowered their prices.
They would sell a lot of springs if their pricing was more competitive.
Old Jan 6, 2010 | 02:34 PM
bat6wc's Avatar
IMPULs are still around $450+ without shipping costs.
i am still considering trying some sport springs and rear sport sway and see what happens.
Old Jan 6, 2010 | 04:03 PM
InTgr8r's Avatar
For all it would cost, it might be worth a try.
There must be someone in your area that has some lying around.
Old Jan 7, 2010 | 09:50 AM
BlueFlash's Avatar
the only problem with them would be the uneven ride height
Old Jan 7, 2010 | 10:01 AM
InTgr8r's Avatar
Not sure what you mean.
Old Jan 7, 2010 | 10:10 AM
BlueFlash's Avatar
there's no guarantee that the even stance of the RWD will translate to an even stance on the heavier AWD.
Old Jan 7, 2010 | 11:20 AM
InTgr8r's Avatar
Ah yes, I see what you mean.
That would hold true for any of the aftermarket springs though.
Several have installed the Eibachs and haven't reported a difference in stance from RWD.
It would vary of course depending on the spring rates of each mfg.
Old Jan 7, 2010 | 01:04 PM
qbturbo's Avatar
I had H & R RWD Sedan springs on my 2004 G35X, even stance and performed well. Not too low, and w/ 19" SSRs, it looked great. I would use H & Rs again when I get the 2010 G37Xs.
