Squeaky noise when going over a dip or bump
Feb 19, 2010 | 02:29 AM
Had the g for about 3+ years and I am noticing some sort of cracking/grinding type noise whenever my car goes over a dip, or bump. Sounds like a wear and tear type of deal but would like to know exactly what it is so I can fix it.
Reply 0
Feb 19, 2010 | 02:39 AM
Sounds like a blown strut
Reply 0
Feb 19, 2010 | 08:17 AM
I would check your sway bar end links.
Reply 0
Feb 19, 2010 | 08:29 AM
Check the sway bar bushings....
After 3yrs chances are good that they need greasing.
Reply 0
Feb 19, 2010 | 09:04 AM
From which part of the car are you hearing this from? If its from the front right it could be the "windshield popping" issue else like others said it could very likely be the bushings.
Reply 0
Feb 19, 2010 | 11:17 AM
The noise is confusing as well.
In the title it's "Squeaky noise" in the post it's "cracking/grinding"
Those are very different symptomatic noises.
Reply 0
