Alignment each summer/winter when running different summer/winter wheels?
Old Mar 23, 2010 | 09:55 AM
hybridamp's Avatar
I'm getting ready to buy a new set of wheels for summer, should I have the car re-aligned every summer and winter when I change the wheels/tires?
Summer: 18x8 +30mm wheels, stock sport tire size
Winter: 17x7.5 +45mm OEM wheels, stock tire size
Old Mar 23, 2010 | 10:33 AM
WhosRich's Avatar
I dont think you need to get alignments everytime you switch wheels.
Old Mar 23, 2010 | 10:37 AM
mishmosh's Avatar
No, definitely not.
Old Mar 23, 2010 | 11:32 AM
hybridamp's Avatar
Excellent.
Old Mar 25, 2010 | 12:57 AM
RCK's Avatar
RCK
I disagree. At least check your alignment. I always have alignment checked when I switch seasonal tires and wheels. Not once have I NOT needed re-alignment. That said, I live in New York {pothole} City. And I am awfully picky.
Old Mar 25, 2010 | 01:49 AM
WhosRich's Avatar
^Maybe its just that you're picky. It seems like overkill to get an alignment everytime you switch wheels for the seasons.
Old Mar 25, 2010 | 01:26 PM
hybridamp's Avatar
Every time I've had alignment checked (usually comes free with rotation around here), the place has "claimed" it needed alignment so I should give them money to do so; even 2 days after having it aligned...
Old Mar 25, 2010 | 02:09 PM
mishmosh's Avatar
If a place takes the time to check the alignment, you can bet they will say it needs one. Like hybridamp, just a 3 months after getting aligned, the place I got new tires at said the alignment was all over and needed one badly. It is easy to doctor. Worse yet, most just zero the toe and call it a day. As long as I don't get abnormal tire wear or the car does not pull to one side, I don't bother to get it checked.
Old Mar 25, 2010 | 02:10 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I get mine done in the spring every year.
It always needs some correction.
rezendvous420
May 31, 2020 01:26 PM
wuppiedog
Aug 7, 2015 11:16 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
itschuckster
Jul 25, 2015 08:07 AM
Soumilg
Jul 18, 2015 12:33 PM
