Will 9.5" wide wheels all around on G35X Work?
Old Mar 24, 2010 | 10:02 PM
cwepruk's Avatar
I have a stock G35xS and DTD has a sale on Privat Reserves in 19x9.5 40mm offset. I am not planning on lowering the car anytime soon, but I might go for the smallest amount if it calls for it.
I just want to know if these will fit/not rub.
I'd guess I have to run 275/35/19 all around too - will this work?
Thanks for the help.
Old Mar 24, 2010 | 10:35 PM
sunny G-35 NYC's Avatar
19x9.5 +40 will work all around no problem but I don't see why you need to run such a wide tire all around. Either 245/35/19 or 245/40/19 all around will work just fine. I would prefer 245/40/19 because it gives a good size side wall and the ride will be more comfortable too, and since your not going to lower the car it kinda helps to fill in the fender gap.
I have a G35xS too and I'm running 20x9 +40 all around with 245/35/20 tire and the sidewall is short and I have to watch the road whenever I drive. I don't rub on anything and my car is lowered with Eibach springs so you will be fine.
Old Mar 24, 2010 | 10:40 PM
cwepruk's Avatar
If I can run 245/40's on a 9.5" wide wheel, all the better. I just figured it would be too stretched.
I'd actually got to 255's since they are only a couple dollars more.
Old Mar 24, 2010 | 10:47 PM
If there is stretch then it will be minimal the way I see it. Just remember to keep the same size rim and tire all around because if the AWD and you'll be fine.
Old Mar 25, 2010 | 08:51 AM
cwepruk's Avatar
Thanks for the help. Will there be any rubbing issues if I decide to go for a slight drop?
Old Mar 25, 2010 | 09:35 AM
suby01's Avatar
no rubbing with 19s and your offest drop and width.
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
kinetek
Aug 3, 2015 04:25 PM
rping
Jul 26, 2015 09:53 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
EasySausage
Jul 14, 2015 11:17 PM
