Reset your TPMS for Free!!
Old Apr 22, 2010 | 04:11 PM
Austin713's Avatar
I just found this thread over at Myg37 and i am so pumped to try this after work. if it does it will save me 120 bucks and a trip to the dealer!!! Has anyone tried this with positive results?
Reset TPMS sensors
Old Apr 22, 2010 | 04:32 PM
headshot's Avatar
Great find!
Old Apr 22, 2010 | 04:41 PM
pczavala's Avatar
Gosh darnit are you serious?! I just went to the dealer last week for this job! and i was searching all over for this.
Old Apr 22, 2010 | 05:39 PM
Austin713's Avatar
i felt the same way!! i wandered into the DIY section over there and it was the first one on the List! i will let everyone know if it works
Old Apr 22, 2010 | 05:42 PM
NJzFinestG's Avatar
does this work for the 04 coupes?
Old Apr 22, 2010 | 05:46 PM
Austin713's Avatar
It should as long as the sensors are infiniti/nissan sensors. it seems to be working for everyone over on Myg37.
Old Apr 22, 2010 | 05:50 PM
same olg's Avatar
That is effffin huge, sick what car enthusiast could figure out about there cars
Old Apr 22, 2010 | 10:40 PM
kool_yaar's Avatar
If this works then this is one of the greatest DIY in a LONG LONG time!!!
Old Apr 22, 2010 | 11:04 PM
SiouxFallsG35's Avatar
Not the first time this has been discovered:
https://g35driver.com/forums/wheels-...ml#post4994403
That thread ended up dieing off with only the original poster confirming that it worked. I never did try it.
Old Apr 22, 2010 | 11:09 PM
HenryLee's Avatar
Great find.
Old Apr 22, 2010 | 11:11 PM
Tool to assist with the job if you don't want to use the paperclip/wire method:
http://www.ntxtools.com/network-tool...p-OTC0203.html
AARONHL's Avatar
I am going to do this soon!
Old Apr 23, 2010 | 10:13 AM
Austin713's Avatar
It worked for me! A couple words of advice.
1. Lose the Paperclip. it is much easier to use some thin gauge wire. there is a larger and a smaller hole. i stuck it in the smaller hole (thats what she said LOL)
2. Ground location. I pushed the start button twice and then immediately touched the wire to the metal surrounding the steering column on the firewall 6 times.
3. Be paitent. it took me several tries to get it right. if the light continues to blink for over a minute you should be good to go. DONT TURN OFF THE CAR or it will erase everything and you will have to start over.
4. Find the freeway. The light will never stop blinking if you arent driving over 30mph for an extended time. mine took about 5-7mins of constant driving
5.Make sure your pressures are right. as stupid as it sounds the pressures have to be exact or it wont work.
when it was all said and done 20 mins of my time and some paitence was alot better than getting bent over at the Dealer!!
Old Apr 23, 2010 | 06:18 PM
CalsonicVQ's Avatar
This TPMS reset procedure is actually described in the factory service manual. However, I don't recall the steps concerning the ECM.
Old May 2, 2010 | 11:17 PM
cwepruk's Avatar
Everything was going according to plan, but after 10 minutes straight of driving, nothing happened (the light now doesn't blink at all - just lights steady). i did the procedure again with the exact same result.
No clue what the issue is.
