Any other tire size for g35xs wheels ???
Old Apr 25, 2010 | 12:42 AM
henryfj's Avatar
Hi..guys,
I have g35x but i have the g35xs wheels. As you know, wheels are 18x7.5 and
tire sizes are 225/50/18. However, is there any other size i can upgrade??
Like 235/45/18 or 225/45/18. Please give me any advices and tell me if i am
wrong with fitment for that size. Thank you.
Old Apr 25, 2010 | 06:57 PM
kregg's Avatar
tire rack shows what width wheels are needed for the tires your buying, and google a tire size calculator if you want to ensure your what the speedo error will be or if you want to match OEM size, it'll also show you how much more or less you'll fill your wheel wells in cause you care about the change in that appearance.
Old Feb 2, 2011 | 11:49 AM
Gregger's Avatar
I had a similar question as well, but purely based on 235's and any rubbing issues. Anyone have an issue?
Old Feb 2, 2011 | 12:50 PM
lundy's Avatar
245/45r18
Old May 3, 2011 | 11:02 PM
machochino's Avatar
OK, I have the xS and it seems the other options are 235/50 and 245/45. I'm really leaning towards the 245 but many say this will create a "tire bulge" on the 7.5" rim. I can't seem to find what it would look like? Any help?
will the 245/45 increase fender gap making it look more 4x4ish on stock suspension?
The 235/50 should fill the wheel well better but make the 18" rims look smaller since it has more sidewall.... I hope I'm understanding this correctly.
Old May 5, 2011 | 06:47 PM
Triton3.5's Avatar
You can't go 245/45 on the stock rims, wheels to narrow,, imo,, u could maybe go 235/50,, but i wonder if you will actuallly use all the tread width... On mine ,, i just went with new 0Z wheels 18x8 with 245/45 w rated Kuhmo's exact same diameter,, and a nice contact patch upgrade.....
Old May 8, 2011 | 12:39 AM
machochino's Avatar
Yea, I like the stock sport rims and I don't feel like paying for aftermarket. I thought 7.5" was the smallest width for 245? I'm just concerned about what possible bulge would happen and what it would look like. Also I kind of think the rims have an OZ look to them!
Old May 12, 2011 | 09:33 PM
hobbs's Avatar
I think most people have gone with 235/50/18s
Old May 12, 2011 | 11:48 PM
machochino's Avatar
Yea I think that's what I'm going to go with. Plus, I think it will look "fuller" with a bit more side wall and fill some of the wheel gap! Now, on to search for the best ones...
Old May 13, 2011 | 12:05 AM
hobbs's Avatar
How about conti dws?
Old May 13, 2011 | 09:23 PM
machochino's Avatar
Those look bad ***. Do people usually recommend buying online and saving money? I see them on discount tire for $748 for the set. Maybe I can find a better deal locally? I've always went into a goodyear or firestone for my previous car.
Old May 17, 2011 | 03:53 PM
dmb4040's Avatar
I have an xS too and was just about to post the same question. With the 235's on the stock 18 inch (7.5) rims, there is no buldge, correct?
Old May 17, 2011 | 10:08 PM
machochino's Avatar
There are pictures of 235/50 on 18x7.5 here https://g35driver.com/forums/v36-gen...r-corners.html
I really want to know what 245/45 would look like.
Old May 29, 2011 | 02:31 PM
machochino's Avatar
I'm giving 235/50 a second thought. It's about 1" larger than stock wheel diameter. Will it hinder acceleration a little bit? But it should give better mileage and better handling with a wider tread correct?
I'm really thinking the trade offs aren't worth it if my xS feels slower with larger tires. Its hard to put the numbers into actual performance
Old May 29, 2011 | 05:13 PM
vqsmile's Avatar
Hunh??
What is your stock diameter? If they're 225/55-17, then the 235/50-18's will only be about .6" taller. If you mean 235/50-17's then it's .4" shorter. EIther is less than 2% deviation.
