Brake Judder
Old Aug 8, 2010 | 04:24 AM
Evos4life's Avatar
Brake Judder
Just wondering if anyone in Socal got this done under warranty. If you did, could please post up the DEALERSHIP you went to and how was the experience. I'm having the same problem so I just want to know which dealership I should go to for less stress LOL. Thanks in advance
Old Aug 8, 2010 | 02:20 PM
gize's Avatar
This doesn't answer your question but is an fyi. Obviously free is better but I bought my 07 used and it had this "judder" going on. I took it to les schwabb, 30 mins and 40 bucks later they filed rotors smooth, had me fixed and rollin.
Old Aug 8, 2010 | 02:23 PM
rpm&my_G35's Avatar
If the cause of the barke Judder is as described in the TSB then it doesn't matter what dealership you go to. They have to address the problem for you per the TSB.
ITB09-037b covers G35sedans 2007-2009
PM me if you want a PDF of the TSB
Good Luck
Old Aug 8, 2010 | 02:28 PM
rpm&my_G35's Avatar
The problem with this is if the problem comes back you likely can't get Infiniti to fix it for you under TSB/warranty...if you have warranty left.
This is what Infiniti will do as per the TSB:
1. Identify the brake system by NMC Model Code or visual inspection.
2. Remove the front brake caliper and rotor.
3. Install the new front brake backing plate (splash guard assembly).
4. Inspect the front brake rotor to determine if resurfacing is possible or if replacement is necessary.
5. Reinstall the front brake caliper.
6. Inspect the brake pads and install the new brake pad kit and new hardware kit if replacement is necessary.
7. Perform procedure on the other side of the vehicle.
Old Aug 8, 2010 | 02:34 PM
gize's Avatar
I am still under warranty till December but didn't think this type of thing would be covered. Maybe I will take it in if the judder returns while still under warranty. I live in UT and we have one Infiniti dealer and my first and only experience is they are very rude, I actually hope nothing steers me their way again.
Old Aug 8, 2010 | 03:49 PM
Evos4life's Avatar
I know that its covered under warranty, I just want to deal with most stress free one LOL. (Sounds kind of weird)
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
