HeLp...staggered wheels for G35X will it affect my VDC?
#31
245/40/19 = 26.7" diameter
275/35/19= 26.6 " diameter
difference = 0.1"
Now, considering the tires have 10/32" or .3125" tread thickness, which is three times the difference between your tires, that means you are essentially rolling on the equivalent of a set of tires that were the same size, but with tread on the rears worn down 1/3 more than the tread on the front. Does that make sense?
Plus, since you're diameter is dead on with the stock diameter, you'll have zero VDC or speedo issues there either. I'd say you nailed it.![Biggthumpup](https://g35driver.com/forums/images/smilies/biggthumpup.gif)
difference = 0.1"
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
I'll let ya guys know come late March/early April, I just put my Blizzaks on!
#33
Well, given the distance, shadowing, and angle, those pics you just posted are not nearly as telling as the first set you posted, NOR do they lend any further support for your assertion, such as pics showing "Five ppl in car and 30 kilo in the trunk" would. Based on your fist set of pics, the only conceivable way that "no rubbing at all" seems remotely possible, is if your spring setup is SOOOO stiff, you are basically riding on 'cement truck' stiffness to the point there's NO actual suspension compression. Such a condition is pretty much the antithesis of the whole term "suspension" and totally destroys your car.
.02
.02
#35
this thread seems to be most helpful in the QUESTIONS i need answering.
I plan on going with the 19x9.5+22 with a 235/35/19 and 19x10.5+22 with a 245/45/19.
my questions is will this set up work?
how do i calculate these sizes to make sure theyre within 1% difference?
any suggestions on tire sizes i should go with?
PLEASE HELP.
PLEASE HELP.
#36
MPG35fiend (07-16-2012)
#38
#39
http://www.miata.net/garage/tirecalc.html
or here:
http://www.1010tires.com/tiresizecalculator.asp
![thewave](https://g35driver.com/forums/images/smilies/th_wave.gif)
#42
If you don`t believe me, here is a video, where you can see how the suspension works and how stiff it is ![Wink](https://g35driver.com/forums/images/smilies/wink.gif)
http://www.youtube.com/watch?v=S-8uaC6Cqj4
![](http://photos.streamphoto.ru/6/0/b/ee114a33b3aac13ad701ba2decdceb06.jpg)
#45
I need help/advice on staggered tires and wheels
Below is what I want to do with my 2007 G35x. The tire dealer is telling me they don't recommend this. What do you guys think?
Potenza S-04 Pole Position
Max Performance Summer
Sidewall Style: Blackwall
Load Range: XL
Serv. Desc: 98Y
Load Range: XL
Serv. Desc: 93Y
Verde
Quantum
19x8.5
Finish: Machined w/Matte Graphite Acct
Load Range: XL
Serv. Desc: 98Y
Load Range: XL
Serv. Desc: 93Y
Verde
Quantum
19x8.5
