new eibach springs for the g35x?
Old Sep 17, 2010 | 08:13 AM
  #31
Frankenstein's Avatar
Not the best pics (early morning, raining, etc) but, here. Because they're progressive rate springs the ride is unchanged under most conditions except that there's less body roll, and less nose/*** dip during braking/acceleration. Over bigger bumps though, the difference is very clear as it's pretty harsh now in comparison to the stock springs...not that this should be a surprise.
Attached Thumbnails new eibach springs for the g35x?-img_0171.resized.jpg   new eibach springs for the g35x?-img_0172.resized.jpg
Old Sep 17, 2010 | 11:02 AM
  #32
lefizzet's Avatar
Nice, finally an even drop!
Old Sep 17, 2010 | 12:59 PM
  #33
jkat13's Avatar
Looks great! Nice and even.
Old Sep 17, 2010 | 03:24 PM
  #34
lundy's Avatar
Post some more pics in a week or so when they've settled. I'm liking the even gappage from front to rear
Old Sep 18, 2010 | 06:56 PM
  #35
Will do! I've had a few chances to push it in the corners and it feels sooo connected, I love it! Now I just have to find a way to slip a set of 20" Forgestars by my wife and I'll be content with the car.
Old Sep 20, 2010 | 06:27 AM
  #36
BloNdine's Avatar
Yep its even but it looks like IMPUL now... i thought it would be lower...
Old Sep 20, 2010 | 12:37 PM
  #37
jkat13's Avatar
Frankenstein,
Can you confirm the drop measurements that Eibach has claimed (1.4" front and 1.1" back I believe)?
Old Sep 20, 2010 | 12:38 PM
  #38
Originally Posted by jkat13
Frankenstein,
I didn't measure before the install - know where I can find that info?
Old Sep 22, 2010 | 01:47 PM
  #39
Dizzo's Avatar
Measure from the ground to the fender after the install. Stock is 28.6 inches on the X. I am on BC and my measurement is 26.25".
Old Sep 22, 2010 | 01:48 PM
  #40
Thanks, I'll check it out when I get home tonight.
Old Sep 22, 2010 | 04:40 PM
  #41
Front: 27 1/8"
Rear: 26 1/2"
I don't know how level the parking lot is but I'll double-check in my garage when I get home.
Old Sep 22, 2010 | 10:34 PM
  #42
efuseakay's Avatar
After a week or so, they should be settled in nicely. And you're right at that point!
Old Sep 22, 2010 | 11:29 PM
  #43
IgS's Avatar
IgS
This is really weird but i did some research and i found this:
Kit# 6388.140 (2008 G37 Coupe) (from a previous post on this board)
Drop = 1.2 (F), 0.8 (R)
Spring Rates:
Front: 228lbs/in initial, up to 548lbs/in
Rear: 371lbs/in initial, up to 531lbs/in
VS:
the new G35X Sedan springs...(off of eibach site)
Pro-Kit #6399.140
Front: Progressive 40-96 N/mm (228-547 lbs/in)
Rear: Progressive 65-93 N/mm (371-530 lbs/in)
Basically identical numbers between the 08 coupe and the g35 sedan? So all this time people could have just used the coupe springs?
i have a G37X sedan, and i used the kit for the regular G37 sedan. I know the fron springs are all the same in ALL of their applications across all the V36 platform G's, but the spring rate is different for the rear.
Thoughts?
Old Sep 23, 2010 | 01:06 PM
  #44
jkat13's Avatar
Are the height of the springs between the coupe and the sedan the same? That could change the drop numbers even though the spring rates are the same.
Old Sep 23, 2010 | 11:44 PM
  #45
bat6wc's Avatar
just a heads up, you can get these for $225 shipped (w/coupon) + a $20 rebate from Eibach through autoanything.
if it wasnt for it being almost october, I probably would have purchased these.
