Staggered Wheels
Old Sep 22, 2010 | 07:35 AM
bpd138's Avatar
Staggered Wheels
Can someone please explain what it means to have staggered rims?
Thanks,
Willie
Old Sep 22, 2010 | 07:56 AM
soundmike's Avatar
It just means one pair of wheels/tires are wider or larger than the other. It's usually the rears being the wider pair.
Unless, of course, you're a FWD dragster where it's the fronts.
Old Sep 22, 2010 | 03:05 PM
Gismyluv's Avatar
If one rim is wider than the other, eg. 8 and 8.5, but the tires are the same size on both rims, is that staggered? Will the overall wheel dimensions be the same? If not, where is the difference? If the difference is minimal, can you rotates the wheels between them? Thanks.
Old Sep 22, 2010 | 03:15 PM
terrycs's Avatar
Still staggered wheels. Wheel widths are different by 0.5". Front and rear tires can be rotated if they are the same size by removing tires from wheels.
Old Sep 22, 2010 | 04:02 PM
LightsOut's Avatar
SIETESG
a coupe guy I came across was able to rotate his sport 19's all being the same size tire and different wheel widths.
only difference running the same size is the tire on the 8.5 will have a slight more stretch than the other. and the tire on the 8.0 will have more tread touching the ground than the other.
vitamin.v
Nov 7, 2019 06:10 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
Slammed_g35
Aug 28, 2015 07:08 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
