Can you replace standard brakes with OEM Sport brakes on a '07 G35x?
Old Oct 8, 2010 | 12:06 PM
Tomek's Avatar
I was wondering what would it take, parts and cost, to replace standard 12.6" front and 12.1" rear brake rotors with the factory 13" rotors. In a dream world, all that it would take is replacing the rotors, but I know that is highly unlikely. I was hoping that by replacing the calipers and the rotors would do the trick.
Old Oct 8, 2010 | 03:40 PM
kool_yaar's Avatar
You will have to change the calipers as well as the rotors since the calipers are different, however its not really worth it, if you are willing to spend $$ on brakes you are better off buying the G37S stock BBK imo.
Old Oct 16, 2010 | 07:08 PM
armoredmoonman's Avatar
Riverside Infiniti sells oem replacement kit for 2k.
Old Oct 16, 2010 | 08:41 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
As mentioned it's a straight bolt on, but requires both caliper & rotor.
I know some have looked at these because of the tendency of the X brakes to develop shudder.
If you can find a good set of used ones it's not a bad upgrade.
IMO, if you're upgrading & buying new; the OE Akebonos from the G37S are buy far the best way to go.
Old Oct 19, 2010 | 02:35 PM
Tomek's Avatar
That is some good advice on the Akebonos. However some of us just prefer the OEM parts over aftermarket. But for around $1500 someone can have a big brake kit, that is very tempting.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
kinetek
Aug 3, 2015 04:25 PM
socalg35x
Jul 28, 2015 10:42 AM
