sway bars
Old Oct 13, 2010 | 06:54 PM
walshtj's Avatar
Just to check, Z sways do infact fit G's correct?
Old Oct 13, 2010 | 07:03 PM
tonke73's Avatar
Originally Posted by Austin713
While on the topic of sways, how many of you have installed aftermarket ones on a Sport model? is there a noticible difference?
Sway bars on any car will make a big difference.
I have Hotchkis sway bars on my sport and it is a great investment.
- Eibach
- Hotchkis
- Stillen
- the list goes on.
Old Oct 14, 2010 | 02:08 PM
Big8Gx's Avatar
So the rear sway bars from an S would fit an X???? and is it a straight bolt on or do you need to do some rigging?
Old Oct 14, 2010 | 02:16 PM
LightsOut's Avatar
SIETESG
direct bolt on.
its the same bar just thicker.
Old Oct 14, 2010 | 07:03 PM
rayneman725's Avatar
hey guys quick update I spoke to a rep at stillen today who actually makes Hotchkis sway bars too, the rep told me the X only has a rear bar because of the way the transfer box sits in the front. they have not made one because their are not enough people that mod the X version for them to make one. I am still going to check with performance dealer near me in the next two weeks. FYI it cost 150.00 for rear bar kind of expensive a bar if you think about it.
Old Oct 14, 2010 | 07:24 PM
E-Ticket Ride's Avatar
Stillen rep told you they make Hotchkis bars?
Old Oct 14, 2010 | 07:32 PM
thats what he said they make them for hotchkis
Old Oct 14, 2010 | 10:04 PM
Although I may be wrong, I'm pretty sure both companies are independent of each other.
Old Oct 15, 2010 | 11:24 AM
LightsOut's Avatar
SIETESG
Dont listen to reps who want your money.
Old Oct 18, 2010 | 07:14 AM
Q8y_drifter's Avatar
Your X has both front and rear sway bars from factory. The rear sway bar is the same design as on the RWD journey and sport model. The sport model has slightly stiffer sway bars. The front on the X is different due to the AWD transfer case. You can install aftermarket sways for the rear made for the RWD model no problem.
Old Oct 18, 2010 | 12:59 PM
djfarhan's Avatar
^ which ones do u recommend?
Old Oct 18, 2010 | 01:50 PM
I'm going with stillen unless someone can post a better product or reason not to
Old Oct 18, 2010 | 02:03 PM
djfarhan's Avatar
let us know how it works out
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
NyCrAzY
Oct 1, 2015 09:19 AM
