Need help lifting
Old Oct 20, 2010 | 07:16 PM
_RR_'s Avatar
Need help lifting
I looked through a couple threads on the subject but really didn't get any clear answers so I made a thread.
I want to change my brakes but the jack I bought won't fit under the front end.
I tried getting it on 2x4s but I still had no room to lift the handle on the jack. Then I see this thread about a nissan pad or a hockey puck to prevent frame damage.
I am just so lost at this point...
I want to change my brakes before I go on a 300 mile trip this weekend. If I need to order something, Ill go to tire kingdom to get it done due to the lack of time. I wanna know for future reference though.
So whats the deal, do i need to get a new jack? Or is there a safe method I can use. I really don't wanna do any damage so is it worth just waiting till I can get my hands on a nissan lifting pad?
-thanks
Old Oct 21, 2010 | 09:54 AM
kool_yaar's Avatar
i just use a standard hydraulic jack that has the circular lifter with cutouts that fits almost perfectly around the jack pinch points(the area between the two cutouts on each side on the lower frame) without any fancy pad or puck and if you do it right and slow enough you will have no frame damage(but do so on your own risk ), i have been doing this forever for oil,brake,tire etc changes.
Hope this helps
Old Oct 21, 2010 | 02:37 PM
LightsOut's Avatar
SIETESG
use factory jack to get the car up and then use a low profile jack.
get some ramps.
Old Oct 21, 2010 | 06:01 PM
_RR_'s Avatar
hmmm, so I should drive partially up ramps, slap a hockey puck on, & jack it? Or should I go all the way up the ramp?
I'm sort of new to working on my own car. Sorry if its a dumb question.
Old Oct 21, 2010 | 06:14 PM
LightsOut's Avatar
SIETESG
object is to get your car high enough to get your jack underneath.
drive all the way up the ramp then jack up your ride. when done slide ramps back under.
use factory jack to lift, then slide your jack under frame and use that as a lifting point.
best and easiest way are ramps.
yes, use the hockey puck.
Old Oct 21, 2010 | 06:27 PM
Project's Avatar
I always use the factory scissor jack. Then just use my regular jack with a piece of wood after its up off the ground a little.
Old Oct 21, 2010 | 10:02 PM
_RR_'s Avatar
thanks guys
Hogbone
Sep 28, 2015 06:44 PM
Dannyy06
Sep 25, 2015 11:32 AM
jbmw002
Sep 10, 2015 12:54 AM
esy
Sep 1, 2015 09:10 PM
