Adjusting Rear Coilover Damper
Old Nov 1, 2010 | 12:38 PM
ChinkyChoy's Avatar
I installed my BC coilovers over a week ago and it rides great i wanted to wait for the springs to settle before i really mess around with the damper settings.
My question is how do you adjust the rear damper setting without lifting and taking the strut out? if its possible.
-Thanks!
Old Nov 1, 2010 | 01:23 PM
beezy619's Avatar
The only way is to drill a hole so you can install the extenders. I think there's a diy for it.
Old Nov 1, 2010 | 01:25 PM
javisaman's Avatar
https://g35driver.com/forums/4083380-post7.html
Old Nov 1, 2010 | 02:08 PM
ChinkyChoy's Avatar
alright sweet i saw this and was hoping there was another way to do it i m guessing this is the same for 1st gen and 2nd gen? also will i have to take the strut out to install the extenders?
Old Nov 1, 2010 | 02:27 PM
bigc's Avatar
Wings Nation
yep, at the very least you'll have to remove the two bolts at the top and compress the strut to give yourself some working room.
Old Nov 1, 2010 | 03:27 PM
soundmike's Avatar
Based on the pic above, you have two options. Doing it as shown in the pic linked to above, with the **** exiting in that cavity behind the seats (it's too short to exit to the top and behind the rear seats), or re-routing the cable back into the trunk from where the hole exits which will require another hole-drilling.
If you decide on the former, here's my DIY on how to "extend" those cables so it'll exit above and behind the rear seats. This allows you to adjust it without removing the rear seats.
http://gshack.org/?p=208
Your other alternative is to ask BC to swap out your existing struts with the newer ones where the adjustment **** is more accessible (don't have a pic, but it's basically on the top-half of the body... you'll be able to adjust just by lifting the car and turning the *****).
Old Nov 1, 2010 | 04:14 PM
E-Ticket Ride's Avatar
You gotta add a pic showing what/where the extender is inside the cabin Mike
mjfenix
Aug 17, 2017 05:49 AM
itztwinki3
Steering & Suspension
Aug 18, 2015 03:38 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
