20x10.5 Wheels
Old Nov 15, 2010 | 06:25 PM
LightsOut's Avatar
SIETESG
what you have is very aggressive and I guessing OP prob isnt trying to go that exact route.
by reading his post, I dont think he knows exactly whats required to make it work.
Old Nov 15, 2010 | 06:30 PM
The Stimulation's Avatar
Yep, it's quite a bit of work. With my +0 up front I have very little clearance from the stock brakes, so BBK's would be worse. I'd say a 10.5 +5 MIGHT be doable but it would be really close to the caliper. Also, it would require upper A arms that can give you -4 camber for sure and it may poke out just a tad too much, hard to tell.
Old Nov 15, 2010 | 06:49 PM
broke_as_ajoke's Avatar
i love the curtains.. pimp all day baby lol
Old Nov 15, 2010 | 06:52 PM
Haha....pimpin indeed. Thanks.
Old Nov 15, 2010 | 10:19 PM
Geemy's Avatar
thanks for the input, running that kinda setup def looks like it requires alot of work. I will most likely be running 8.5's up front. Your car looks great btw ballar curtains
Old Nov 16, 2010 | 10:31 PM
Shurik355's Avatar
I've seen The_Stimulation's G before but what he did to his rear wheels and how much camber it has in the back is just plain stupid! I'm sorry but it just does looks ridiculously retarted. The car is meant to have a custom wider body for that kind of a set up, but so far I don't see that. The fronts are bearable though, and looks not that bad. Oh but the wheels look sick, love the Varianza T1S... but the wrong width + wrong offset and that camber just kills it. I mean why man? WHY? lol
I mean if the offset and the width of the wheels is not anyway near to fit on the car, just don't do it and save yourself a lot of trouble in the future. + it will look right, and good.
Old Nov 16, 2010 | 10:54 PM
Geemy, yep quite a bit of work. You can still do 9.5's up front with no problems at all. Thanks for the compliment on the curtains
Shurik, simple answer, I like being different and not blending in. If I could fit a tire on 12" wide wheel I would throw on a 20x12 -8 but I have enough issues with tires rubbing as it is.
I probably could have kept my previous setup and dial in positive camber and it would look much more even with the front but I wanted to challenge myself. Figured I'd max out the charts that Work has to offer.
And no worries, I've had people tell me that the rear looks stupid, retarded, etc. Doesn't bug me because I know it's not for everyone. It serves it's purpose though, turns heads all the time. Even with guys that had a 6 figure car break their necks looking at it, lol.
Old Nov 17, 2010 | 12:23 AM
Shurik355's Avatar
I hear you bro, but when people look and turn their heads it's less likely positive. It's most likely "WTH is that?" "WTF is he thinking?" probably calling you stupid and all kind of names you know. Unless they give you thumbs up
But hey Im not hating, just not liking it at all. It just doesn't look anyway near being "right".
I would say if you want to challange and make your G different/unique, go widerbody bro. Custom or perhaps with some sort of a widebody kit, that would set it up very nice! I've seen one guy with his V36 do it, and THAT looks different (really unique). + a widerbody would look much more clean and with style, without noticable damage due to rolling of fenders or rear quarter wheel well.
Old Nov 17, 2010 | 12:35 AM
Yeah I get that, but I also do get thumbs up. It all depends on the person.
Custom widebody is down the line. At that point I'll still run a good amount of negative camber, probably around -5 or so to match the fronts, but that won't be for quite some time.
Old Nov 17, 2010 | 01:02 AM
lundy's Avatar
Thumbs up
Although your rear tires are scary stretched and your style is a little more aggressive than mine I give you props and a thumbs up indeed. Don't mind the haters.
Old Nov 18, 2010 | 05:06 PM
da mayor's Avatar
this is 20x10 front.... 40mm offset no rubbing on a 235/30/20 tire
Old Nov 18, 2010 | 09:27 PM
Thanks lundy.
da mayor, looks sick!
Old May 25, 2013 | 12:14 AM
mike1991g35x's Avatar
Originally Posted by The Stimulation
Yup, here's a couple. First one is the most recent. Just lowered it some more.
Here's my build progress thread as well:
https://g35driver.com/forums/picture...g35-sedan.html
so it is possible???? i am planning on getting 20x10.5 vossen cv3 all aorund .. they came in today , i had originally ordered 20x9 all around but i didnt like them because it was not concave enough for me the guy at the rim shop was telling me the 20x10.5 willl not fit in the front , but i have seen alot of ppl on here with that fitment. so my question is, do u rub? or is everyting all dandy?
Old May 25, 2013 | 07:13 AM
so in that case 20x10 vossen cv3s all around a g35x sedan would fit no problem?
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
