Circuit Sport (Alutec) Strut Bar
#32
Just a heads up - I received my bar today from FRSport and it looks slightly different from the one you have pictured. There is no "Alutec" badge and no part number sticker. It also doesn't have the three small holes drilled on the ends. Aside from those minor differences, it looks like it's the same bar. I actually prefer it without the Alutec logo. I haven't tried installing it yet, but will report back once I do.
"Alutec" badge removal: this is no different from debadging emblems. Heat with heat gun or hair dryer. Use tooth floss to separate the badge. Clean adhesive residue with Goo-Gone.
#33
Originally Posted by soundmike
Just a word of caution, this apparently won't work with CAI's because of how the pipes come out of the TB's.
Thanks again Soundmike for introducing this strut bar and the awesome review!
#36
Looking at picture of the Injen CAI, their proximal pipe actually flares out more and sits higher than the Stillen does. This probably has the pipe in contact with the bar at the same point as the black **** but at the front of the bar instead of the back. I knew looking at Soundmike's pics that my Stillen would probably work.
If you have a solid pipe aftermarket intake, I would look at your setup and compare with pictures very carefully before buying the Alutec.
#37
^ yes i will be doing that for sure, just have to commit some money aside for this first, then i will take soundmikes generous offer and ask him to measure the distance between the bars curve and the stock intake tube near the TB and then make my decision since i have the R2C which has the straighter pipes unlike the stillen which curves down.
#39
#40
http://www.frsport.com/Alutech-IG102...e_p_26105.html
is that the right item? the other link says 'item deactivated' but this says COUPE ONLY!
#41
#42
#43
chat I just had from FRSSports
-Thank you for contacting us. An operator will be with you shortly...
- Ryan: Hi, I was wondering what happened to part FST-037C-AT is ALT-IG102 an identical replacement?
- Operator Mike joined the chat
- Mike: let me take a look
- Mike: yes it is
- Ryan: I know people have been running FST-037C-AT on the g35 HR sedan (07/08) and the ALT-IG102 says coupe only
- Ryan: but if it's identical I know it'll fit
- Mike: alutec
- Mike: use to make the strut bar for cs
- Ryan: ah so its just the label change then?
- Mike: i do believe so
- Mike: yes it is
- Mike: alutec
#45
Just got one installed. Got it from ebay for $169 delivered. I prefer this design to the other brand based on the fact that I don't have to install cards with it and the fact that it is a solid piece.
http://cgi.ebay.com/ebaymotors/Circu...item25671473d3
I know it's a huge link but this is the available auction. I got mine in 3 days and it was exactly what I wanted.
