G35/37 19" Coupe wheels on X?
Old Dec 12, 2010 | 06:52 PM
Gregger's Avatar
I'm still learning about my 08 X sedan and searching didn't find a whole lot of info.
Can I run the Rays coupe wheels on my X? Is the offset correct? I know some of the models had staggered offsets.
Any help would be great.
Old Dec 12, 2010 | 10:23 PM
s.liu17's Avatar
Yes you can since the diameter of the wheel/tire isnt changing. Though you will need to make sure you get the tires put on are the same exact diameter all the way around.
Old Dec 12, 2010 | 11:17 PM
Gregger's Avatar
Ok. I had thought the G35 sedan had different offset wheels so you couldn't rotate front to back. Maybe that's not true on the X models.
Old Dec 13, 2010 | 01:15 AM
kool_yaar's Avatar
well if you get the 19" from the g37, then they have to be from the S model, which are staggered, meaning rear are wider than fronts, so rotating them will not be possible considering you will probably end up with uni-directional tires which wont allow any rotation.
Old Dec 18, 2010 | 07:00 PM
cwepruk's Avatar
I run G35 Rays with 255/40/19's all around. Looks great, fits great, perfect offset - but can't be rotated.
Old Dec 19, 2010 | 03:30 PM
Gregger's Avatar
Thanks brother. I'm trying to find a set, but everyone seems to have stripped/painted theirs that are being sold. Looking for the perfect set.
Old Jan 29, 2011 | 09:48 AM
TShepp's Avatar
I am also considering the g37 coupe rims on my 08g35X sedan. One question I have is; would it be better to buy 4 rear coupe rims and run them all around on the sedan or just run the normal staggered setup?
Old Jan 31, 2011 | 01:24 PM
G force's Avatar
Depending on the tire, you can still rotate side to side with a staggered set-up, the stock Potenzas can be rotated side to side.
Old Jan 31, 2011 | 03:03 PM
lundy's Avatar
Thats what I would do but it's hard enough to acquire the regular staggered setup IMO. I think it would be difficult to find 4 rears. But if you could
Old Feb 6, 2011 | 10:55 AM
TShepp's Avatar
Well, I ended up just buying a mint staggered set with tires for $1100...Pretty good deal from what I have seen.
Xfactor
Dec 1, 2019 12:52 PM
Brodys_GCoupe
Nov 7, 2015 08:06 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
