Dumb question about mounting winter rims
Old Dec 17, 2010 | 01:00 PM
JMZ_blkobsidian's Avatar
Ok, so my winter rim/tire combo arrived from Tire Rack and I'm trying to mount them. Car is a 2007 G35S 5AT
Removed front, driver side wheel. In addition to the 5 lugs, there is a cylinder (~0.5" diameter, 1" long) protruding from the wheel hub. This protruding cylinder prevents the wheel from fitting on because the protruding cylinder does not line up with one of the trapezoidal openings that are between the lug holes on the wheel.
Is this protruding thing necessary, did TR send the wrong wheels???
TIA
Old Dec 17, 2010 | 01:01 PM
mishmosh's Avatar
That is just to remind you not to install the stock rear wheels on the front. You need to remove it to use aftermarket wheels.
Old Dec 17, 2010 | 01:04 PM
Great...
Thanks for the quick response...I figured it was to ensure you don't screw up the staggered setup.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
multimut
Canada
Jul 26, 2015 08:43 PM
