07 G35 Sport Sedan Brakes are Killing me!!
Old Jan 3, 2011 | 09:31 PM
Calpolytlo's Avatar
So I used to frequent these boards much more when I first got the car.
Only problem I've had is the brake shudder usually at freeway speeds.
I've looked through these threads all over the internet spoken to mechanics.. .
So far what I have tried.
1) Had the rotors turned. This fixed the problem for a few days( about a week) then eventually the shudder came back.
2) Months later and fed up. Replaced the rotors entirely, and threw on some ceramic pads. Felt ok for a few days (about a week). . . now I'm back to square one.
I'm really looking for anything here now fellas. .. anything you could throw my way. . .I love my car aside from the shudder and I want to get back to loving it 100% I'm almost to 80K!
Old Jan 3, 2011 | 10:17 PM
boostd7's Avatar
[QUOTE=Calpolytlo;5577380]So I used to frequent these boards much more when I first got the car.
does it shudder when you apply the brake? maybe check the balance on the wheels, not just the cheapo balance. A road force balance when they load the wheel.
maybe one of the pistons is bad causing uneven pad pressure???
Old Jan 3, 2011 | 11:10 PM
Calpolytlo's Avatar
[QUOTE=boostd7;5577530]
Yeah only when I apply the brake. I considered uneven pad pressure. .. but I mean how can you test for that? My pads and even rotors look to have even wear
Old Jan 3, 2011 | 11:28 PM
stardust's Avatar
Have you been using a torque wrench to tighten the lug nuts?
Old Jan 3, 2011 | 11:44 PM
Calpolytlo's Avatar
I'll be honest the first time I had the rotors turned no I didn't . .. but rather "free handed it"
Second time with new rotors and new pads . .yeah I used a torque wrench and the star pattern for tightening. . . so no I don't think its that. . .
Old Jan 4, 2011 | 06:40 AM
6mtg37s's Avatar
What pads do you have? Id say get better ones
Old Jan 4, 2011 | 06:55 AM
boostd7's Avatar
+1 to that, while you are at it might as well swap out for fresh brake fluid. brake fluid when it starts to break down will let air into your hydraulic line in as early as months. the air in your lines could cause the shuddering b/c you are not getting even pressure. I would definitely swap out the brake fluid. how old is it? don't to by what it looks like. go by age. put some high temp dot 5 in that bish.
Old Jan 4, 2011 | 11:41 AM
djfarhan's Avatar
yknow bout the brake judder tsb right?
Old Jan 4, 2011 | 12:38 PM
Austin713's Avatar
^^ what he said... Infiniti will install some splash shields on the hubs to keep water from splashing up and warping your rotors as easily... im at 57k. replaced my front pads at 25% life with EBC red stuff and did not resurface the rotors. i have no vibrations.
Old Jan 8, 2011 | 02:27 PM
Calpolytlo's Avatar
Wow! Girlfriends Uncle who who works for Infiniti looked at it. .. he drove with me experienced the vibrations first hand. . . .first words out of his mouth . ..
Rear rotors are warped
I say no way . . .. can't be
he turns them. . . new pads
problem solved!
dude. . . I'm relieved but in disbelief. . . would have never guessed it was the rears wtf!!??
Jusseth
Sep 13, 2020 12:25 PM
teamghost
Jul 28, 2015 04:52 PM
crazy_g35s
Jul 20, 2015 02:30 PM
