I just installed the Tanabe NF210 Springs. Front is ok but rear is a little lower and I got problems entering my garage (it touches the new tiles on it, ouch!!).
Is there anything I can put in the rear springs to make it a little higher?
Thanks to all in advance.
Do you have an x, bc the tanabes sag in the rear on the x's. If you have a rwd, the fender gap should be even front and back.
I have Tanabe NFs on my wife's car and it does sit a little lower in the rear than the front, but it will sag quite a bit more on a g35x
Quote:
Nope, G35SOriginally Posted by platinumg35x
i believe there is a solid bushing product out there you can install to add height but for the life of me i can't remember. ill look into it on google but otherwise there isn't much you could do....perhaps you got a defective batch...have you called/emailed tanabe?
I don't think using a bushing is a good idea, it is better for you to change another new set of springs...sell the one you have and buy new ones
