allignment and brakes
Old Mar 22, 2011 | 01:47 PM
zoop425's Avatar
I was driving yesterday and realized that while going strait my wheel is a bit crooked.. and the bezel around it seems off too.. idk what happened lol.. I guess im going to bring it in for an allignment to get that fixed. I also feel a brake judder so new pads and roter re-surface? What pads should I get for the optimal performance and last. (2007 g35x)
Old Mar 22, 2011 | 02:47 PM
dohturdima's Avatar
If you are under warranty and have the original rotor/pads with brake judder TSB never applied, sign up at infinitihelp.com and download the brake judder TSB (Technical Service Bulletin) ITB09-037b for our cars. Then go to your local dealer with the brake judder TSB printout just in case and have them cut/replace front rotors and replace pads on your front brakes as per TSB. You can have the dealer do an alignment but if I were you I would take the G to a local Firestone and get a lifetime alignment for the same price.
Old Mar 22, 2011 | 06:07 PM
zoop425's Avatar
Thanks a ton. Called my dealer and set up an appt for the brake warrenty and rubber trim replacment
Old Mar 22, 2011 | 06:22 PM
gary c's Avatar
Good advice....^....with the exception of taking your G to Firestone. It's not required to have your alignment done often, maybe when you get new tires. What's that every 3 to 4 years and the clowns at F-Stone aren't the best mechanics or they wouldn't be working there, kinda like Sears or PepBoys. Watching those mechanics work is like watching a monkey f^ck a football! Every neighborhood has a reliable independent brake/alignment shop, that's where you need to spend your $$. Just visit your Infiniti dealership for warranty work, that's all they're good for with poor quality work and jacked up prices!
Gary
Old Mar 22, 2011 | 08:03 PM
zoop425's Avatar
I would never go there.. I would rather Mavis do it.
Old Mar 22, 2011 | 10:32 PM
dohturdima's Avatar
I sometimes use Firestone for those $20 oil change/tire rotation specials and so far they didn't forget to put the oil in or to tighten the filter so I thought for routine alignments they can't be too bad. Guess I was wrong.
Old Mar 22, 2011 | 10:36 PM
dohturdima's Avatar
No problem. FYI, they have to add splash guard shields as a part of the TSB, as they seem to protect the rotors from unevenly cooling and causing pad material to transfer which results in judder. My rotors were cut twice due to judder prior to TSB being applied and since then no judder for the past 10K miles even though I stuck with the same dusty/noisy OEM pads.
Old Mar 22, 2011 | 11:14 PM
zoop425's Avatar
Is there a way I can check to see if the splash guards were added? I looked at the service records from the past owner and he has the TSB done but it was under a year ago so I assume the issue is still there (therefor not done fully)
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
