Hub centric ring
Old Apr 9, 2011 | 10:52 AM
celwin's Avatar
Hub centric ring
I lost one of my hub centric rings for my wheels. where do I get replacements and what size do I get? can i drive around with one wheel missing the ring? I already mounted 3 wheels and don't really want to unmount them again.
Old Apr 9, 2011 | 12:39 PM
kool_yaar's Avatar
driving without one should allow noticeable vibration through the car and is not recommended cause then you are centering the wheel with lug nuts which is not meant to be the case in our cars which use the hub to center the wheel.
You can get them almost anywhere online, just google it, ebay should have them cheap or you can get it from forum vendor.
I believe our OEM bore is 66.1 and then it depends on what wheel bore size you have, just check other ring to see the required size. example, it could be 73.1-66.1 or 72.6-66.1 etc.
Hope this helps
Old Apr 9, 2011 | 05:35 PM
celwin's Avatar
Hope this helps
Thanks. Found the missing ring after all so did not have to ride around without it.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
the93owner
Oct 4, 2015 09:40 AM
w4kj4k
Oct 2, 2015 07:57 PM
Terry_G35
Sep 10, 2015 08:17 PM
