Camber Arms
Old Apr 21, 2011 | 02:46 PM
G35sTIMCA's Avatar
Question Camber Arms
Hi all
I am lowering my car with Tein S-Tech, Tokico Blues. I want to get camber arms to get my car back to alignment spec.
When I search for arms, I see there are bent arms and straight arms, both of which are listed as camber arms. When I look at an exploded view of the parts, it looks like the bent arm is the camber arm and the straight arm is the toe bar.
Does anyone have part numbers and recommended brands? I have a 07 G35s (Gen II) 6MT sedan.
Lastly, is the toe bolts a necessity or can I get back to stock alignment without them?
Thanks
Tim
Old Apr 21, 2011 | 03:54 PM
terrycs's Avatar
Originally Posted by G35sTIMCA
Hi all
Thanks
Tim
Eibach resells the SPC camber kits for our cars. 2 rear kits are available. The cheap one ONLY comes with toe bolts. The expensive one comes with camber arms AND toe bolts. You need to get the expensive one for the rear.
Eibach also resells the SPC front camber arms (AKA Upper Control Arms or UCAs) now.
Check the Eibach website for part numbers.
Old Apr 21, 2011 | 03:58 PM
G35sTIMCA's Avatar
Thanks for the reply! So I am assuming I can either go with Eibach (which are really SPC's) or SPC's.
Old Apr 21, 2011 | 04:04 PM
terrycs's Avatar
Yes, they are the same. But from what I've seen, the Eibach version is less expensive. It's probably dues to their much higher volumes.
Look around and see what you can find.
Old Apr 21, 2011 | 04:08 PM
G35sTIMCA's Avatar
Awesome!!! Thanks for the help!
Tim
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
