11" Wide Tires Possible?
Old May 24, 2011 | 07:14 PM
tpc303's Avatar
^ very nice
Old May 24, 2011 | 07:21 PM
B L U E S L A T E's Avatar
Honda Accord
Depends on the offset i think. THe Wheels i bought had a +27 around, and i have 10.5 in the rear. Had to pull all my fenders to get the wheels to fit the car. Have you test fitted it yet?
You didn't have to pull the fenders to fit your wheels, Yoshi. Like I told you before, you could have pulled it off by just stretching the tires a bit.
Old May 24, 2011 | 07:42 PM
bluedevils95's Avatar
^ Dude! My wheels were poking out 1 1/2 inch, and w/ people sitting in the back i wouldn't have tires. Now i am tucking a bit since i drop the car. Plus now i like the fenders pulled b/c it adds a new look to the G
Old May 24, 2011 | 07:46 PM
Honda Accord
You only pulled the fenders cuz you didn't want to stretch tires and having negative cambers.... although your current setup is still stretched and cambered.
Go put on some spacers! It's gonna look even better.
Old May 24, 2011 | 07:51 PM
I am still rubbing in the back and when i have a friend in the front seat i hear the back going down. My camber is -2 and i have 275 in the rear. I think i need like 245 and my side wall needs to be less then 15 to pull that off.
Old May 24, 2011 | 07:59 PM
Honda Accord
You're doing something wrong then. Without the fender pulls and 275 tires on my 10.5 wheels, I was never rubbing in the rear. Oh and the camber was set at -1.8 in the rear with me inside. I understand that your offset is about 10mm more aggressive, but that shouldn't make much difference given you have some 2" pull in the fenders.
Old May 24, 2011 | 09:17 PM
jimboG35x's Avatar
im running 10.5 in the rear with 275 tire i will take a pic 2morrow
Old May 25, 2011 | 01:28 AM
JDMPenn's Avatar
I would probably pull my fenders. I want to minimize camber and poke as much as possible.
Old May 25, 2011 | 01:49 AM
Oh! what was your offset?
Old May 25, 2011 | 01:42 PM
jimboG35x's Avatar
hear is the pic,
Old May 26, 2011 | 07:26 PM
lundy's Avatar
That's a lexani LSS-10, they don't make 10.5's
Old Jun 2, 2011 | 04:38 PM
terrycs's Avatar
Depending on wheel design or unless one likes deep wheel lips, I'd rather not deal with camber and stretching tires.
285 on 10", and zero camber can be done using +48 offset.
The benefits include max contact patch on the ground and no inside tire wear due to camber for max tire life.
Just my opinion.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
socaldavid
Sep 5, 2015 04:35 AM
