Tire size double check before I place order. thanks.
Old Jun 13, 2011 | 07:06 AM
boostd7's Avatar
My wheels should be refinished this week. I m getting the coils hopefully today. I just want to verify the tire size before I ordered them. thanks a million.
wheels are blitz type 03 wheels
18x8 in front with +45 offset
18x9 outback with +45 offset
I will need spacers.
I am going with 245/45 zr18 in front
275/40 zr 18 outback
thanks.
Old Jun 13, 2011 | 08:08 AM
soundmike's Avatar
Yep, those work.
Old Jun 13, 2011 | 08:30 AM
boostd7's Avatar
Originally Posted by soundmike
Yep, those work.
forgot to mention they are for a 2008 x..... i m sure that doesn't matter. but i don't want to screw i up
Old Jun 13, 2011 | 08:58 AM
boostd7's Avatar
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
225/55-17 4.9in 13.4in 26.7in 84.0in 754 0.0%
245/45-18 4.3in 13.3in 26.7in 83.8in 756 -0.2%
275/40-18 4.3in 13.3in 26.7in 83.8in 756 -0.3%
I don't want the vdc to get all screwy. It doesn't tell you how wide the tires are. I don't want to rub a hole in my fender area. thanks
EDITED: thanks soundmike
Old Jun 13, 2011 | 10:22 AM
soundmike's Avatar
Hmmm... wait, your first post said 245/45, but your post above this shows 245/40. The first one is fine, but that second one is a bit too short IMHO. Up to 3% error is considered fine in the industry, 3.8 is a bit too much. Any reason for the change of mind on this one?
Your wheels are relatively conservative both in width and offsets, i doubt you'll rub anywhere, especially after the drop.
For comparison, i have +38 9.5" wheels with 255/45 all around. There's a lot of space towards the fender and suspension side. The only thing that rubs with my camber settings is a very slight one between the wheels inner lip and a small area of the front Eibach sways at full right lock.
Your wheels will tuck in slightly more, but will also have more space on the suspension components side as they are a bit narrower.
Old Jun 13, 2011 | 10:45 AM
boostd7's Avatar
thanks for the correction. I edited it. what kind of spacers should i go with. 20MM all around????
Old Jun 14, 2011 | 12:57 AM
vqsmile's Avatar
Just thinking options.....Why the 17" wheel with a skinny tire in front? Why not a 225/50 on an 18" wheel to match the 275/40-18, or an even wider 235/45-18 with a slightly narrower 265/40-18 in the rear?
Old Jun 14, 2011 | 07:29 AM
soundmike's Avatar
^ I think he was comparing his OEM set-up with the aftermarket he's planning on getting.
235/45 and 265/40 is a little small for his application. It will work, but there's less difference with the other sizes. Also, again, just me, but 225 on an 8" wide wheel is a little stretched.
boostd, for spacers, i suggest you get the drop dialed in and wheels on first then measure how much of a spacer you'll need to flush it out to taste.
Old Jun 14, 2011 | 08:04 AM
boostd7's Avatar
[QUOTE=vqsmile;5938520]Just thinking options.....Why the 17" wheel with a skinny tire in front? Why not a 225/50 on an 18" wheel to match the 275/40-18, or an even wider 235/45-18 with a slightly narrower 265/40-18 in the rear?
that's just a tire size calculator..... to see how close it is to the stock set up. i am going with 245 and 275 in the rears.
Old Jun 14, 2011 | 08:11 AM
boostd7's Avatar
boostd, for spacers, i suggest you get the drop dialed in and wheels on first then measure how much of a spacer you'll need to flush it out to taste.[/QUOTE]
I am going to have to drop it first. I have no idea what it will look like. I will let it settle for a day or two, take measurements and go from there. stupid question i guess. I am gonna go for the flush look. I am trying to flush out my rx7 too.
damn this forum. I saw all the hellaflush wheels
Old Jun 14, 2011 | 09:37 AM
vqsmile's Avatar
Ahh, gottcha. I thought those were the pairs. I definitely like the wider set.
marsman328
Northern California
Aug 11, 2015 07:29 PM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
will091195
Jul 27, 2015 09:19 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
