BC CO Rear Dampening Adjustment (RWD)
Old Jun 30, 2011 | 07:57 PM
2007BlueSlate's Avatar
I have been riding around on the BC CO's for a while now and love the way they feel. However, I was a rear passenger in my car the other day and noticed that the rears are set way to soft and would to adjust them.
I know that since the dampening setting is on top of the CO I need to take off the shock absorber but my main question is if I can take off the sock absorber without removing the springs.
Can someone please advice me on the easiest way to get to the dampening settings? I know there is a guide on here to drill a hole through the backseat frame but I don't want to go this route. Thanks in advance.
Old Jun 30, 2011 | 08:14 PM
tpc303's Avatar
I ran my extenders up through the backseat. No drilling and I can reach them from the backseat. I'll post pics when I get home
Th
Old Jul 1, 2011 | 12:24 PM
^ Sounds interesting. I'm taking it you put in the extenders when installing the CO and not after.
Old Jul 1, 2011 | 06:32 PM
soundmike's Avatar
Yes, you can take the damper off without removing the spring, but it's easier if you loosen the spring bucket. To do just the dampers, remove the bolts/nuts, loosen the locks on the damper then turn it to shorten, this will ease removal, but take note where you were to begin with so you can put it back at the same length.
If you just want to attach the damper adjustments at the top without removing the shocks, drill a much larger hole at the top behind the seats (which you have to remove, to access this location), you can then attach the extensions to the adjustment **** that way. The larger the hole, the easier this is to do.
Old Jul 5, 2011 | 04:26 PM
^ Is it possible to drill this hole without taking off the shocks or do you need to take them off first?
Old Jul 6, 2011 | 02:07 AM
xr0ckstar's Avatar
I'm in the same boat with my Ksport Coilovers. I saw the DIY on drilling the hole , so I went ahead and removed my back seats and started drilling. To my surprise after I got the hole made there was a soft gray or black rubber piece . there was some lettering on it that said "pvcl" and "looka" or something like that. I tried my best to take a picture through the hole. I didn't wanna start drilling through the rubber without knowing what I was doing, so I put it all back together. Any info would be appreciated.
http://img221.imageshack.us/i/imag0301j.jpg
http://img695.imageshack.us/img695/1783/imag0302x.jpg
http://img97.imageshack.us/img97/3707/imag0303ui.jpg
Old Jul 6, 2011 | 08:32 AM
soundmike's Avatar
It's hard to see in your photos, but if that rubber is what i think it is, they are the covers that go between the tower and the top of the shocks -- my guess is to provide a weather-seal and prevent moisture from accumulating in that cavity. I didn't bother putting mine back on as it was too short to go over the somewhat long-ish adjustment ***** on the BC rears.
Also, i don't know with the Ksport, but with the BC's, that hole you drilled is just enough for the cable to go through. To attach the BC adjustment cables, the hole has to be bigger so the whole **** that connects to the ***** on the shock can fit through with enough space to pass an allen wrench through and tighten it down.
Lastly, for those doing this, BC's include rather short cables for the sedan, but you can extend this using speedometer cables. I have a how-to here - http://gshack.org/?p=208. If i had to do this again, i would get thicker cables. The longer they are, the thicker it needs to be so there's no slack when turning.
Old Jul 6, 2011 | 05:00 PM
xr0ckstar's Avatar
@Soundmike I didn't wanna start out with a huge hole. Good thing I didn't cuz I woulda ripped the rubber. Oh geeez my mind is in the gutter
so I guess to be safe I should remove my rear coil and back seat, then drill from the bottom up ? unless someone else can confirm what the rubber is.
Old Jul 6, 2011 | 08:06 PM
soundmike's Avatar
It's actually easier to drill from the top down, so i would suggest continuing what you did if you want to pursue drilling the hole.
rezendvous420
May 31, 2020 01:26 PM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
