No hub centric rings for 66.5 to 66.1?
Old 07-01-2011, 09:46 PM
Anton_Chigurh's Avatar
Looking for these rings for my new wheels and i can't find a set at all..only ones i can find are custom for $100...WTF
New wheels are 66.5 and stock is 66.1
Old 07-02-2011, 03:00 PM
aToxic's Avatar
Have the same problem with my Vossens CV1
Old 07-02-2011, 04:12 PM
are you running them on your car now? Any problems?
Old 07-04-2011, 04:29 AM
aToxic's Avatar
They are on. No problems for now (installed & tightened wheels on thruster). But problems (vibrations) can appear after the first removal and installation of wheels. If they appear, i`m looking forward to add spacers with different (in and out) DIA
Old 07-04-2011, 10:34 AM
UCIMAplaya2's Avatar
You want a ring that will adapt your 66.1mm hubs to 66.5mm wheel hubs? So the overall diameter difference is 0.4mm? And since this is a ring the thickness of your new ring will be 0.2mm??? Am I missing something?
Old 07-04-2011, 11:19 AM
This is why i am asking..do i need a ring if the difference is only .4 MM very very small difference
Old 07-04-2011, 11:26 AM
sunny G-35 NYC's Avatar
I dont think you need one for that size, but you'll find out after putting on the wheels.
Old 07-04-2011, 12:42 PM
mishmosh's Avatar
I think 0.4mm is enough to cause problems. Every hubcentric ring I have used is very snug to the wheel and the hub. If I were you, I would spend a lot of time mounting the wheels, making sure the lugs get tightened by hand very gradually in a star pattern, before you torque them down.
Old 07-04-2011, 06:42 PM
vqsmile's Avatar
Originally Posted by mishmosh
I think 0.4mm is enough to cause problems. ...
Uhmm....that's less than 8 thousandths of an inch. Pull out your feeler gauges and look at what that amounts too. That's only a few times more than what main bearing clearances are for lots of engines!
Old 07-04-2011, 06:52 PM
mishmosh's Avatar
hey, I can mount wheels without the hubcentric rings and get it on center less than 1/2 mm. The problem is vibration at speed.
Old 07-04-2011, 07:15 PM
The shop will be doing it as i won't be...
There are no rings for a .4MM difference so i am going to have to mount them without it..hell i could put one piece of tape around it and there is .4mm
Old 07-04-2011, 10:06 PM
if you want to go that route then buy some copper wire and put it around the hub it its possible
Old 07-10-2011, 11:43 AM
drivethefive's Avatar
so what mm difference would warrant the use of hub centric rings? Also, is there a way to check that on the specs of the wheels? Getting ready to buy some 19's soon and need to determine if I have to factor in the cost of rings as well.
Old 07-10-2011, 05:48 PM
mishmosh's Avatar
If the center bore of your wheels does not match the hub size, you need hubcentric rings. If you are buying new wheels, I would try to get the retailer to throw in the proper hubcentric rings. I know Tirerack does this as standard practice, as well as throwing in the proper lug nuts.
Old 07-10-2011, 10:16 PM
^ make sense, I'll keep that in mind when I buy so I don't have to purchase them. Seems like lots of place give you a wheel price then beat you down with all the extras including shipping! What is considered not matching? 65, 67 close enough? I actually looked at a set today that was 73, seems pretty far off...
Quick Reply: No hub centric rings for 66.5 to 66.1?
