Brakemotive "ebay" drilled/slotted rotor review
Old Jul 4, 2011 | 09:32 AM
Texasscout's Avatar
Originally Posted by kool_yaar
^ yes i have seen those as well, but compare the lower rusted drilled hole with the cracked one and see the difference in thickness, its very obvious the owner let the rotor wear down well below its minimum thickness.
Once the chamfered area is "compromised" u need new rotors, which is why having D/S is a better idea as once the end of the slots are starting to disappear you know its time to change your rotors and avoid such mishaps.
Most d/s rotors site state ... "The slots and diamonds are machined to the minimum rotor thickness to insure rotor strength and integrity" Once you see the slots starting to even out with the rotor switch out
Hardly, you didn't look close enough, the champhers are still there, they were less than 6 months old. They measured WELL within spec.
Old Jul 5, 2011 | 05:35 PM
rvanderwerf's Avatar
how thick are those rotors? Mine are just shy of 1/2" on each side, those look a lot thinner?
Old Jul 5, 2011 | 05:57 PM
kool_yaar's Avatar
Very possible and very interesting, but not shocking, iv seen a few crack while still being relatively 'new' so i guess it could have been a bad batch or something else that explains it since they are a good company. Iv had mine D/S R1 for 40k+ ~3+years with no such issues(fingers crossed) and they have been introduced to rigorous braking at times.
Old Jul 5, 2011 | 08:58 PM
Rollo's Avatar
I didn't measure them but they looked about the same size as the OEM's and are at least as heavy. I kept the OEM's just in case of a tragedy but I really don't think they will be a problem.
I have read about some cheaper ebay rotors being low carbon steel and comparatively very soft but I doubt these are like that. Like I said, I'll get 20 thousand miles on them in a year and should have a good idea if they are soft within 6 months.
Old Jul 5, 2011 | 09:39 PM
19kdrill's Avatar
Great info guys. I'm in the market for rotors and would like to keep the cost at a minimum. I do not do performance driving, therefore am not very hard on brakes at all. Might look into these a little more.
rob.g
Old Jul 5, 2011 | 11:30 PM
Actually I was asking the guy with the cracked rotor. It looked way thinner than mine.
Old Jul 6, 2011 | 08:24 PM
Texasscout's Avatar
I don't have them anymore, they went to the scrap yard where they belonged in the first place.
BTW: I was using EBC "green stuff" pads with these. Loved them, but they eat rotors like candy.
Old Oct 13, 2011 | 05:04 PM
stpolo's Avatar
Great info Rollo! Just wondering how the brake setup is holding up?
Old Oct 14, 2011 | 04:54 PM
Rollo's Avatar
I have over 6 thousand miles on them now and they are holding up perfectly. No rust, no judder, just execllent performance. I'll update again next year when I have over 10k on them. Here is what they look like now...1 front and 1 back one...
[IMG][/IMG]
[IMG][/IMG]
Old Oct 14, 2011 | 04:58 PM
19kdrill's Avatar
Purchased a set myself. Got about 3k on them, so far so good...
Old Jan 1, 2012 | 06:16 PM
Rollo's Avatar
Bad news for me...the front rotors have developed a high speed brake judder and I think it is worse than the stock ones had before I replaced them....but the stocks had 40k miles on them.
The rotors still look great and have no rust. Also I have not had the TSB for installing the splash shield so I may try to get that done before I change the fronts out again.
I contacted the ebay company and they said they only had a 120 day warpage warranty but offered to sell me a new set at a discount. I will probably replace the fronts with R1 premiums or the Barkeperformance dimpled though.
With only 10k miles on the pads is there any reason I couldn't just replace the rotors my self and leave the current pads in place? They seem to work well.
Old Jan 1, 2012 | 07:34 PM
mishmosh's Avatar
That sucks. I would definitely get the TSB splash shields installed. You really should get new pads when going with new rotors but I can see your point about only having 10k miles on them.
Old Jan 1, 2012 | 10:33 PM
Bigd2k6's Avatar
I'm looking at replacing my front/rear pads and don't like the idea of having my car down for a whole day while they machine the OE rotors. I saw a suggestion on the Z forum of these rotors for a quick and cheap swap. Glad I didn't get 'em and sorry they didn't turn out so good for you.
Old Jan 13, 2012 | 07:37 AM
Mkai0's Avatar
Thanks for the review, I almost pulled the trigger on a set of Ebay rotor and brake set for my car because the brake judder on my stock rotors. Is the judder normal for our cars or does this mean my rotors are warped?
Old Jan 13, 2012 | 12:20 PM
  #30
vqsmile's Avatar
Originally Posted by Mkai0
... Is the judder normal for our cars or does this mean my rotors are warped?
Judder is fairly common for these cars, although it's hard to say which you have. Judder is normally caused by uneven pad transfer (glazing) of the rotors and it can occur independent of actual warping of the rotor, yet exhibit symptoms similar to warping, so you may have one or the other or both going on. Classic judder is as described in the TSB.
