Would they fit?
Old Sep 21, 2011 | 08:11 PM
jdm7's Avatar
Would they fit?
I have an old set of wheels mounted on winter tires from my Evo X and I was going to sell them, but maybe I'll just use them this winter if they fit or I can't find a buyer....
Evo X wheel specs:
18x8.5
+38 offset
mounted on 245/45/18 winter tires
What do you think?
Old Sep 21, 2011 | 08:12 PM
LordFappington's Avatar
Hmm... Title is misleading was thinking this was about gangbangs
Old Sep 21, 2011 | 08:15 PM
Jeff92se's Avatar
Red Card Crew
Actually trial fitting would answer your question 100%
Old Sep 21, 2011 | 08:17 PM
sunny G-35 NYC's Avatar
If the center bore is the same then they will fit no problem.
Old Sep 21, 2011 | 08:28 PM
jdm7's Avatar
lordfappington...your name proceeds you....carry on.
center bore is 67.1mm for the Mitsu wheels....looks like the 2007 g35 s 18" wheels are 66.1....no good then?
Thanks so far guys
Old Sep 21, 2011 | 08:51 PM
Jeff92se's Avatar
Red Card Crew
Hole is bigger than the Nissan requires.
Old Sep 21, 2011 | 08:53 PM
You need hub centric rings then they would fit. You can install them without the hub rings, but you might get some vibrations in the steering wheel
Old Sep 21, 2011 | 09:16 PM
jdm7's Avatar
yeah that's what I was thinking. Looks like they can be had for pretty cheap, so maybe I'll pick up a set of 66.1mm ones if I decide to use the wheels. Now it's a matter of figuring out if its worth it to sell them because of the wheel+tire+sensors packaged. It's too bad the sensors wouldn't work with the infiniti
Can the TMPS light be shut off on the 07 G35? (pretty sure they can't)
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
dseet
Oct 11, 2015 12:40 AM
Claudiu
Sep 26, 2015 01:04 PM
