Noise from Blizzaks or wheel bearings???
Old Nov 15, 2011 | 10:28 PM
JohnPawlak's Avatar
I had Bizzaks put on my 2007 G35S recently, and wholy crap are they noisy. This is the 3rd winter I've used them and I just don't remember that much noise in past years. From about 10 MPH down to 0 when breaking, it sounds like a prehistoric animal groaning. I thought perhaps it's the front wheel bearings going. Jacked the car up, and the bearings feel completely smooth, with no play. Car has ~60K miles on it. Noise sounds like it's coming completely from the front (and I have the Bizzaks on all four). Worse in turns - left turn = right side noise, right turn = left side noise.
Any one else had bearing noise without the bearings showing any other problems like binding or looseness? I'm tempted to replace one hub just to see if it makes a difference. Thanks!!!
Old Nov 16, 2011 | 02:31 AM
vqsmile's Avatar
I'm confused. You say you put the winter tires back on and then the noise started. Is that right?
It seems like the test would be to (temporarily) swap back to the summer tires and verify that the noise is, or is not, still present. I wouldn't recommend swapping out a hub/bearing under the circumstances you've described.
Old Nov 16, 2011 | 08:54 PM
awais's Avatar
I just put on LM-25s and I notice the sound as well when coming to a stop.
Old Nov 19, 2011 | 05:38 PM
JohnPawlak's Avatar
Yeah, but I only have one set of rims. I suppose I could try the spare. I actually think it's both, a wheel bearing dying plus the snow tires. Before the snow tires were on I was noticing the noise a little, but seems worse with them on. I bought a hub online. I'll put it on next weekend and see if it helps.
Thanks.
Old Nov 19, 2011 | 05:47 PM
redpearl99's Avatar
just put on my winters and exactly the same thing happened to me. i think winter tires are just much nosier
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
wuppiedog
Aug 7, 2015 11:16 AM
rping
Jul 26, 2015 09:53 PM
