Clicking/grinding rear differential noise
Old Mar 31, 2012 | 06:23 PM
pride's Avatar
My V36 7AT sedan seems to occasionally make a loud clicking/grinding noise when turning right and inching up a fairly steep inclined driveway. I have Hotchkis sways set on the middle position. I was wondering if anyone else with Hotchkis sways experienced this noise. I'm thinking the diagonal incline approach unloads the right rear wheel and causing it to catch and slip alternately. TIA
Old May 13, 2013 | 06:15 PM
obsdnoblivion's Avatar
Hey what did you discover about this? I have a noise when I curve right or turn right. It sounds like it's coming from the right, too. I know it's not the bearing and I thought it could be the brake shoes inside the rear right rotor but I adjusted them down to make sure they would have to not even be barely touching the inside of the rotor and I still hear the noise. I hope if it is an issue down that far inside that it's the axle and not the diff.
rezendvous420
May 31, 2020 01:26 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
ScraggleRock
Aug 11, 2015 10:16 PM
atk08
Jul 30, 2015 03:12 PM
rping
Jul 26, 2015 09:53 PM
