H&R DRM spacers
H&R DRM spacers
Dropping my X on Prokit and getting 20mm spacers for rear. But 15 or 20 for the front? I have stock S rims 18x7.5 all around.
I hear the wider wheel base up front will increase turning diameter or am I over-analyzing a 5mm difference. Anything else I should consider like if the front wheel well is narrower, thus I may need less spacing up front, since all my rims are same width. Maybe 20mm up frnt and 25 rear?
I saw white g35s on NF210 springs and 20mm all around with sport rims- 2GorNot2G? Looks so clean.
soundmike, thanks for putting it in perspective! lol. I was actually thinking car will look better with 25mm all around since the rims are narrower and given offset?
Well... probably safest to go with 20mm
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
FreshVQ
Sep 30, 2015 01:41 PM
