Aggressive Rear Fitment setup help!
Old Feb 16, 2014 | 11:10 PM
clamchauda931's Avatar
hey guys. i searched around the forum and read somewhere for the v35 that -1 degree of camber gives about 5.75 mm of clearance. I assume that the v36 sedan is similar but i was wondering if anyone has measured this specifically for the V36.
Ive attached a couple of photos showing my problem.
do you guys think an extra degree of camber will remedy my problem? clears the tire perfectly but will not clear the rim lip.
edit:
WHOA sorry guys i have no idea why the pictures ended up being sideways
Attached Thumbnails Aggressive Rear Fitment setup help!-g35fit.jpg   Aggressive Rear Fitment setup help!-g35fit2.jpg   Aggressive Rear Fitment setup help!-g35fit3.jpg
Old Feb 17, 2014 | 12:05 AM
Pepper's Avatar
-1 more degree will most likely not let the lip of the rim clear the quarter. You will either have to add a few more degrees or a pull and a couple degrees.
mjfenix
Aug 17, 2017 05:49 AM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
Soumilg
Jul 18, 2015 12:33 PM
